Hello everyone, I need some help with a project. I will be using a circuit to drive a automotive gauge stepper motor using an analog sensor to provide pressure input.
I am starting with and arduino to mock up everything. For the life of me I cannot figure out how my ford Mustang oil pressure sending unit works.
This particular unit has 3 pins. Pins 1,2 and 3 are labeled "oil pressure switch", "signal return" and "Vref". I am assuming Vref is 5V and pin 1 is ground and pin 2 is signal 0.5-4.5V.
When I check continuity between the threaded portion and pin 1, I see no continuity without pressure and no continuity with pressure (slowly ramping from 0-80 psi).
When I hook the sensor up to a 5V source with Pin 1 set to ground and read pin 2 I see 0.5V constantly no matter what pressure is applied to the sensor.
Please help!
