So I had an old inkjet printer lying at home that no longer worked. So I opened it up and found a few opto sensors and normal motors controlling to carriages.
What do you want to use the printer parts for? You certainly won't be able to do printing with an Arduino.
A printer that I dismembered had cheap DC motors and an incredibly fine optical encoder disk and strip. If yours is like that I doubt if an Arduino would have the performance to detect the optical stripes unless the encoder is moving very slowly. I have never tried to use mine.
My guess is that the printer manufacturers spend (spent might be a better word) a great deal of money on software that allows them to use cheap motors. It pays off when you need to buy 2 million motors.
Robin2:
Indeed. Only a couple of days ago I pulled a cheapo Canon printer scanner to see if I could get some parts - maybe a stepper motor or three that I might be able to the pulleys off. It's a changing world..... They had been replaced by cheap motors with optical encoders with plastic ribbon or disk, one of which was beyond my understanding, and all I got was a glass plate from the scanner. After throwing the rest out, I realised that the optical encoder that I couldn't understand was probably where the fault lay, and it may have been fixable.
(pardon the hijack)
All those printers have a beautifully polished stainless steel rod that the carriage moves on. Save that for use in your metalworking shop. You do have a shop, don't you?
Paul_KD7HB:
That describes the usefulness of a salvaged printer so wonderfully
