Oled 128x64 display error
Hello...
I have connected a wemos d1 mini to an oled 128x64, and when I upload a test file everything works fine, but when I load the sketch it goes wrong, my knowledge of Arduino programming is on the low side, so any help is welcome ;- :
I see two bars on both sides of the display and I can't get rid of them!
Where should I look for the error?
//  ***mods by vk3pe Jan 2023.   Compiled using Arduino IDE Ver 1.8.19
//    Added address 0x60 for Si5351 module I used. ie my own Si5351 PCB
//    Currently modified to run on the 10M band.
// Jan 24th 2023 added an OLED display to show the various states of the ESP3266_WSPR
// The additions are prefaced by "//OLED" to show the changes.
// Si5351 CALibrated using https://raw.githubusercontent.com/etherkit/Si5351Arduino/master/examples/si5351_calibration/si5351_calibration.ino
//  to obtain CAL factor.
// 7hi x 6w Pixels for Font(1),      12hi x 12w ? for Font(2)
//ESP_WSPR_ver_3_006
// Simple WSPR beacon for ESP8266, with Si5351A Breakout board
// FIX CLK0 Output for 20 m band with Fast time sync to prevent weather dependent time drift.
// Hardware info
// serial debug port baud rate: 115200
// Si5351A is connected via I2C on pin D1 (SCL) and D2 (SDA) as marked on Wemos D1 mini Lite
// freq0 is used in clock0 output. It runs with 8mA output setting as standard  > vk3pe
// Hardware Requirements
// This firmware must be run on an ESP8266 compatible board
// tested on Wemos D1 Mini
// Required Libraries
// Etherkit Si5351 (Library Manager)
// Etherkit JTEncode (Library Manager)
// Time (Library Manager)
// Wire (Arduino Standard Library)
// NTPtimeESP
// ESP8266WiFi
//*******************************[ LICENCE and CREDITS ]*********************************************
// Original Code of Multiband NODEMCU WSPR by Marco,IW5EJM
// Modified for one output, fast time sync and LED mode flash modifications by Barbaros Asuroglu,WB2CBA
//Simple WSPR beacon for ESP8266, with the Etherkit or SV1AFN Si5351A Breakout
// Board, by Jason Milldrum NT7S.
// Original code based on Feld Hell beacon for Arduino by Mark
// Vandewettering K6HX, adapted for the Si5351A by Robert
// Liesenfeld AK6L <ak6l@ak6l.org>.  Timer setup
// code by Thomas Knutsen LA3PNA.
// License
// Permission is hereby granted, free of charge, to any person obtaining
// a copy of this software and associated documentation files (the
// "Software"), to deal in the Software without restriction, including
// without limitation the rights to use, copy, modify, merge, publish,
// distribute, sublicense, and/or sell copies of the Software, and to
// permit persons to whom the Software is furnished to do so, subject
// to the following conditions:
// The above copyright notice and this permission notice shall be
// included in all copies or substantial portions of the Software.
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
// EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
// MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
// IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR
// ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
// CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
// WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Hello all,
I realized it's quite difficult to find precise information about defined WSPR frequencies for all available bands. So I wrote a list for all bands, here you go! The TX frequency center is always +1500 Hz above the dial frequency.
last update: 2018/01/18
----------Band----------Dial Frequency----------TX Frequency center(+range)--------------
2190m--------------0.136000---------------0.137500 (+- 100Hz)
630m----------------0.474200---------------0.475700 (+- 100Hz)
160m----------------1.836600---------------1.838100 (+- 100Hz)
80m------------------3.568600---------------3.570100 (+- 100Hz) (this is the default frequency in WSJT-X v1.8.0 to be within the Japanese allocation.)
80m------------------3.592600---------------3.594100 (+- 100Hz) (No TX allowed for Japan; http://www.jarl.org/English/6_Band_Plan/JapaneseAmateurBandplans20150105...)
60m------------------5.287200---------------5.288700 (+- 100Hz) (please check local band plan if you're allowed to operate on this frequency!)
60m------------------5.364700---------------5.366200 (+- 100Hz) (valid for 60m band in Germany or other EU countries, check local band plan prior TX!)
40m------------------7.038600---------------7.040100 (+- 100Hz)
30m-----------------10.138700--------------10.140200 (+- 100Hz)
20m-----------------14.095600--------------14.097100 (+- 100Hz)
17m-----------------18.104600--------------18.106100 (+- 100Hz)
15m-----------------21.094600--------------21.096100 (+- 100Hz)
12m-----------------24.924600--------------24.926100 (+- 100Hz)
10m-----------------28.124600--------------28.126100 (+- 100Hz)
6m-------------------50.293000--------------50.294500 (+- 100Hz)
4m-------------------70.091000--------------70.092500 (+- 100Hz)
2m-----------------144.489000-------------144.490500 (+- 100Hz)
70cm--------------432.300000-------------432.301500 (+- 100Hz)
23cm------------1296.500000------------1296.501500 (+- 100Hz)
On all bands you have to use USB mode. Please check local licence conditions and band plans prior transmitting !
And always keep in mind that power output >5W is considered as QRO on WSPR!
Best 73 de
Saki, DD5XX
//*********************************[ Libraries ]*****************************************
#include <si5351.h>
#include "Wire.h"
#include <JTEncode.h>
#include <int.h>
#include <TimeLib.h>
#include <NTPtimeESP.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
//******************************[ DEFINE'S ]********************************************
#define TONE_SPACING            146           // ~1.46 Hz
#define WSPR_DELAY              683           // Delay value for WSPR
#define WSPR_CTC                10672         // CTC value for WSPR
#define SYMBOL_COUNT            WSPR_SYMBOL_COUNT
#define TX_LED_PIN              2  //integrated onboard led
#define SEND_INTV     10
#define RECV_TIMEOUT  10
#define SI5351_REF     25000000UL  //si5351’s crystal frequency, 25 Mhz or 27 MHz  >>> 250006000UL? for vk3pe build.
//**************************[ USER DEFINED PARAMETERS DECLARATION ]***********************************
//unsigned long freq =     14097100UL; //Frekansi farkli WSPR bandlari icin degistirebilirsiniz. Change this for different band frequencies.
//unsigned long freq = 10138700UL; //Change this for different band frequencies.  >>>> vk3pe 30M band
//int32_t cal_factor = 0; // SI5351 Kalibrasyon Katsayisini buraya giriniz.  SI5351 Calibration factor obtained from Calibration firmware plugged in here.
int32_t cal_factor = 133200;    // for PD8GB
const char* ssid = "**----------**";           //Sizin WIFI SSID'nizi buraya girin. SSID of your Wifi network        *****
const char* password = "---------";   //Sizin WIFI sifrenizi buraya girin. Password of your wifi network    *****
char call[7] = "PD8GB";  // Sizin Cagri Kodunuzu buraya giriniz. USER CALLSIGN *****
char loc[5] = "JO32";    // Sizin MAIDENHEAD KONUMLAMA GRID'inin ilk dort harfini nuraya girin.Ankara icin KM69. USER MAIDENHEAD GRID LOCATOR first 4 letters. *****
#define TIME_ZONE +1.0f    //WAS +3 VK3PE //UTC ve LOkal zaman farkini buraya girin.(Turkiye icin +3 saat girili) Your time zone difference in regards to UTC (floating point number)
//*********************************[ END OF USER DEFINED PARAMETERS ]**********************************
//****************************[ VARIABLES DECLARATION ]************************************************
uint8_t dbm = 22;                     //Tx power *****  standard barefoot power out of this project is about +10dBm. 100mW = +20dBm, 200mW = +23dBm.
uint8_t tx_buffer[SYMBOL_COUNT];
const char* WiFi_hostname = "ESP_WSPR";
//Sync clock every 12 hours
#define NTPSYNC_DELAY  1
//NTP Server:
const char* NTP_Server = "ntp1.inrim.it";
//Si5351 si5351;
Si5351 si5351(0x60);       //added by vk3pe jan 2023 to ensure I2C ADDR for my own Si5351 pcb
JTEncode jtencode;
bool warmup=0;
NTPtime NTPch(NTP_Server);
strDateTime dateTime;
//add OLED -----------------------------------------
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
// OLED display TWI address
#define OLED_ADDR   0x3C        //usual I2C address for OLED's.
// reset pin not used on 4-pin OLED module
Adafruit_SSD1306 display(-1);  // -1 = no reset pin
//****************************************[ TIME SYNC FUNCTION ]******************************************
time_t epochUnixNTP()
    digitalWrite(TX_LED_PIN, LOW);
    Serial.println("- NTP Time Sync...");
    Serial.print("- NTP Time:");
    NTPch.setSendInterval(SEND_INTV);
    NTPch.setRecvTimeout(RECV_TIMEOUT);
    do
      dateTime = NTPch.getNTPtime(TIME_ZONE, 1);
      delay(1);
    while(!dateTime.valid);
    NTPch.printDateTime(dateTime);
    setTime(dateTime.hour,dateTime.minute,dateTime.second,dateTime.day,dateTime.month,dateTime.year);
    Serial.println(now());
    digitalWrite(TX_LED_PIN, HIGH);
  return 0;
//*********************************[ WSPR ENCODE and TRANSMIT FUNCTION ]**********************************************
void encode()
    uint8_t i;
    jtencode.wspr_encode(call, loc, dbm, tx_buffer);
    Serial.println("- TX ON - STARTING TRANSMISSION...");
      //OLED
      display.clearDisplay();
      Erase_text2();
      display.setCursor(05,33);       //,10
      display.setTextSize(2);        //text size
      display.print(" Start Tx");
      display.display();
    // Now do the rest of the message
    for(i = 0; i < SYMBOL_COUNT; i++)
        si5351.set_freq((freq * 100) + (tx_buffer[i] * TONE_SPACING), SI5351_CLK0);
      delay(WSPR_DELAY);
    // Turn off the output
    si5351.set_clock_pwr(SI5351_CLK0, 0);
    Serial.println("- TX OFF - END OF TRANSMISSION...");
      //OLED
      display.display();
      Erase_text2();                  //black out lines. ie delete
      display.print ("  End Tx   ");
      display.display();
//*****************************************[ WIFI CONNECTION FUNCTION ]****************************************
void ssidConnect()
  Serial.println("- ESTABLISHING WIFI CONNECTION TO:");
  Serial.println(ssid);
  Serial.println(password);
  WiFi.begin(ssid, password);
 Serial.print("- Connecting");
    delay(300);
    delay(300);
    Serial.print(".");
  Serial.print(F("- Connected to: "));
  Serial.print(F("- IP address: "));
  //Add OLED
  // display a line of text
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(14,10);     //01,50 vk3pe
  display.print("IP Adr: ");
  display.display();
  //display.setCursor(01,20);
  display.print (WiFi.localIP());
  display.display();
  delay(2000); //temp
void Erase_text2(){
  // fillRect(x corner, y corner, width, height, color)
  // Draws and fills rectangle from corner x,y with the width and height
      display.fillRect(1, 30, 127,18, BLACK);     //,15, bl
      display.display ();
void Erase_text1(){     //text size 1
      display.display ();
//**************************************[ SETUP FUNCTION ]*************************************************
  //OLED
    // initialize and clear display
  display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR);
  display.display();
  display.setCursor(01,01);
  display.print("ESP8266_WSPR");
  display.display();
  //added callsign at bottom      //vk3pe
  //display.setTextColor(WHITE);
  display.setCursor(21,55);
  display.print("     PD8GB");
  display.display();
  // Use the ESP8266 LED as a keying indicator.
  pinMode(TX_LED_PIN, OUTPUT);
  Serial.begin(115200); while (!Serial);
  Serial.println("                    ");
  Serial.println("[ ESP WSPR - ESP8266 + SI5351A WSPR BEACON FW: ESP_WSPR_ver_3_006 ]");
  Serial.println("- SERIAL COM setup Done!");
  delay(10);
  WiFi.mode(WIFI_OFF);        //Prevents reconnection issue (taking too long to connect)
  WiFi.mode(WIFI_STA);        //This line hides the viewing of ESP as wifi hotspot
  ssidConnect();
  // Set time sync provider
  setSyncProvider(epochUnixNTP);  //set function to call when sync required
  // Initialize the Si5351
  // Change the 2nd parameter in init if using a ref osc other
  // than 25 MHz
  Serial.println("- RADIO MODULE SETUP Begins...");
 // The crystal load value needs to match in order to have an accurate calibration
  si5351.init(SI5351_CRYSTAL_LOAD_8PF, 0, 0);
  // Start on target frequency
  si5351.set_correction(cal_factor, SI5351_PLL_INPUT_XO);
  //si5351.init(SI5351_CRYSTAL_LOAD_8PF, SI5351_REF, CORRECTION);
  Serial.println("- RADIO Module initializing...");
      //OLED
      Erase_text2();
      //gpp display.setCursor(5,30);
      display.print("Module initialize");
      display.display();
  // Set CLK0 output
  si5351.set_freq(freq * 100, SI5351_CLK0);
  si5351.drive_strength(SI5351_CLK0, SI5351_DRIVE_8MA); // Set for max power
  si5351.set_clock_pwr(SI5351_CLK0, 0); // Disable the clock initially
  Serial.println("- Radio Module setup successful...");
  Serial.println("- Entering WSPR TX loop...");
   //OLED
   Erase_text2();
   display.setCursor(10,30);
   display.print("Module is setup.");
   display.setCursor(10,40);
   display.print("Enter Tx loop.");
   display.display();
//*****************************************[ LOOP FUNCTION ]******************************************************
  // Trigger every 4 minute
  // WSPR should start on the 1st second of the even minute.
  // 30 seconds before trigger enable si5351a output to eliminate startup drift
  if((minute() + 1) % 4 == 0 && second() == 30 && !warmup)
    { warmup=1; //warm up started, bypass this if for the next 30 seconds
    Serial.println("- Radio Module Warm up Started...");
      si5351.set_clock_pwr(SI5351_CLK0, 1);
      //OLED
      //clr prev text
      Erase_text2();
        display.display();
      display.setCursor(20,33);
      display.print("WARM UP !");
      display.display();
  if(minute() % 4 == 0 && second() == 0)
    { //time to start encoding
      Serial.print("- Start of Transmission Time:");
      Serial.println(now()); //prints on serialport actual time
      encode();
      warmup=0; //reset variable for next warmup cycle wich will start in 4 minutes and 30 seconds
      delay(4000);
      //OLED
      Erase_text2();
      display.setTextSize(1);  //text size
      display.display();
      display.print("Start Tx timing !");
      display.display();
 //*************************************[ END OF PROGRAM ]********************************************************
Verify your OLED seen and at the right address with this I2C scanner...
That the first thing i did when i saw it did not work properly, but the adress is oke.
If I could put an image here, I could show that some of the text is coming into view, but it is not in place where it should be.
Two bars also appear on both sides
Read 10 posts in 10 topics for 10 minutes and you will get image posting privileges.
