hello guys whats your opinion on this tft ? 3.2inch 16BIT Module ILI9341 SKU:MRB3205 - LCD wiki
im searching for something easy to setup that wont require me to try 3124234 libraries and keep on changing stuff to make it work
Since you are looking for something easy to set up, almost all of Adafruit's displays come with complete, clear wiring instructions and example code.
The company also supports its products. If you choose one and follow the instructions, it will work as advertised. In the rare case it does not, Adafruit will usually replace it.
It has to match your needs. Support (already mentioned), simplicity of setting up, response times, daylight performance, touch screen etc. etc. Some of these characteristics are trade offs. For example, good daylight performance usually means slow response times.
I'd rule it out as a general purpose display because of the number of GPIO pins it would require but it could be fast to refresh.
IHi Gortyy
In your situation i would certainly go for the (well engineered) Adafruit product.
Success, Photoncatcher
