OPTREX Display - more info needed
I got a 6.5inch screen from work, seems like it's this one: http://www.esis.com.au/LCD-Monitors/Optrex65inLCD_opr01PPR.pdf
I would like some information on how to connect it to the arduino - if possible.
Has anyone else tried this screen?
What parts do i need to be able to connect it to the arduino?
Images:
http://bit.ly/HvAG8w
http://bit.ly/HvAF4J
http://bit.ly/I6antO
http://bit.ly/HvAHJR
http://bit.ly/HvAPJj
http://bit.ly/I6aHbQ
http://bit.ly/I6aNjY
http://bit.ly/HvATZn
http://bit.ly/I6aWDN
http://bit.ly/I6b0Ue
http://bit.ly/HvAWo3
You probably need something like this: PICASO QVGA/VGA/WVGA Graphics Controller - DEV-10329 - SparkFun Electronics. It has the VGA interface and the RAM needed for a full color frame buffer. Another option is the gameduino shield Gameduino - DEV-10593 - SparkFun Electronics.
You might find other options is you google arduino+vga.
Actually it looks like it doesn't have a standard VGA connector. Did it come with a cable adaptor? If not you'll have to source a connector for it and mash together a cable. The marketing brief you posted doesn't mention the physical interface and may only be using the term "VGA" to describe the screen resolution, in which case it may have a proprietary or standard digital interface which means you are not likely to find a ready-built driver shield or adaptor for it. You can't use it without some additional hardware since it will need about a meg of RAM for its display buffer.
Datasheet from the mighty google: http://welecw2000a.sourceforge.net/docs/datasheets/T-51750GD065J-FW-AA.pdf. It has a 31 pin digital interface with a minimum clock speed of 20MHz, 3.3V and 5V supplies.
You can build your own driver board using the datasheet.
