PCB LM1117 problem
it's been a while since my first pcb try (only the sketch), now i had some time to actually etch it and solder.
I'm having some problem with the LM1117, it's not outputing power i dont know why.
as you can see in both pictures, connections seem to be correct.
I've tested and it receives 5v at input pin.
Any ideas on what could be happening
The pinout for an LM1117 is different from that of an LM7805.
oh my god, i'm so stupid i didnt even noticed that.
What's the best way (if there's any) to correct the pcb without too much modifications ?
Carlcox89:
Cut the traces and use wires to jumper it correctly. You're not the only one who has flubbed like this.
You can turn the regulator sideways and bend the leads into the correct position.
@LarryD, that's what i did :wink:
thank you all
