PIR motion sensor - HC SR501 --> need low output on detection
Hi there!
I am working on an alarm clock. I'd like to make the screen light up when motion is detected and let the backlight go out again after a while.
This was no problem. But I'd also like to put my Arduino to sleep while I'm not using it using the powerDown sleepmode.
My problem is that I read it can only react to LOW level interrupts, while my PIR sensor outputs HIGH when motion is detected.
Is there a workaround for this?
Thanks!
Bram
Put a transistor between the output of your sensor and the Arduino input, this inverts the signal.
Are you sure you need this work around?
Grumpy_Mike:
OK, that looks interesting. I'll have to look whether I won't have more leaking amps over there than just keeping the Arduino active.
Well, I think so....
Other than in active mode the external interrupt pins can only detect a LOW level
(ATmega328P wakeup from sleep via interrupt - heliosoph)
