Hello community,
I have a question about how to track position of an object. This is an interesting one because it’s a fuel level gauge. It’s one that mounts to a tank and is visible through a plastic tube. The tube is approx 4” tall and .75” dia and has a round plastic indicaticator that travels up and down approx 3” in total to indicate fuel level.
I was thinking of using a couple photocells and LED to measure light position...?!? As the plastic indicator passes from top to bottom I may be able to get a consistent light pattern that I can write code for.... Not sure.. also amibient light could affect the photocells too much...
However, there maybe there is some kind of proximity sensor that may work?!
Any advice, thanks all!
