I trying to setup my 80 watt ( 10w output ) Diode laser modul to my arduino - cncshield with GRBL. but the laser cant run on 100 % power.
specs. on the laser says PWM 3 to 12 Volt, but the PWM signal on arduino is only 5 V. And when I run 100 % power I only get 4.25 V on the PWN on the laser.. 2.13 V with 50 % power.
I use 15 Amp PSU, and all core is 1.5 mm2 and the PWM signal is taking from Z+ pin
the power on the laser goes down to 10.79 V. with 100 % power. turnt off there is 12.24 Volt.
it run and work okay, just the problem the laser only works half
Can anyone help my ? I think I do everything.. I also replace the Uno and cnc shield ( new ) replaced all wires .. Another PSU and the laser is brand new..
Im not sure, because a lot of peoply say , yes its a signal to on / off laser, but also the signal controls the power. Zero volt is off, 6 V. is 50 % and 12 V is 100 % I dont know if its wrong, but my problem is the laser wont cut thru someting ( not enough power ) and there is only 4.25 V .. The specs. says PWM 3 - 12 V. perhaps meen my laser only runs around 30 %
You can control the power by a DC voltage (0-12V) or by PWM. Stay a bit below 100% duty cycle so that the laser can distinguish a PWM signal from constant voltage.
