I want to have a power switch on a PCB I am making, but all of the cheap ones have a rated current of less than 300mA. This is not enough for my project. Has anyone seen any TRUE, but small (I don't want a big rocker switch) switch with a current of an amp or so? Or should I use a switch/transistor arrangement to switch the load?
While you gave a current specification you didn't mention physical size and stype of switch you want. Certainly there are many switches out there that would meet your needs if you can give more details of what you want.
I'll start again with what I want to do, in greater detail.
I am making a PCB for a microcontroller, which is powered by a DC barrel jack. I want a switch on some sort so that I can turn the micro on and off w/ out unplugging the jack. From the switch, the power is feed to a 7805, which powers the micro. I want the board to be small, so a transistor/switch may not be the best idea. I'll keep looking for switches, I guess.
