Problem in arduino UNO while controlling BLDC motor
I am making project where I have used all the 12 pins of arduino (from 2 to 13). It is done to run a bldc motor which has three hall sensor that provide +5 or 0 V depending on rotor position. The hall sensor`s signals are input to arduino.
The following short description is given here to indicate the pin no. used in this program.
int Y = 3; // Q1_Output which goes to the gate driver circuit of a three phase inverter
int J = 5; // Q2_Output to the gate driver circuit of a three phase inverter
int Z = 6; // Q3_Output to the gate driver circuit of a three phase inverter
int I = 9; // Q4_Output to the gate driver circuit of a three phase inverter
int X = 10; // Q5_Output to the gate driver circuit of a three phase inverter
int Q = 11; //Q6_Output to the gate driver circuit of a three phase inverter
int C = 7; // H1_Input from motor hall sensor
int A = 8; // H2_Input from motor hall sensor
int B = 12; // H3_Input from motor hall sensor
int S = 2; // PWMm_Input from an electronic circuit which gives +5 V and 0 v
int D = 4; // PWMr_Input from an electronic circuit which gives +5 V and 0 v
int E = 13; //C_Input from a 5 V source which is given from another microcontroller and a pull down resistor (6k) is used TO this pin as well.
The problem i faced is very different. The motor runs for a 1 to 2 minutes and then all the outputs pins of the arduino either goes LOW or HIGH which causes motor shut down. If I press reset button again then it works for some moments nicely then again it goes.
So, what is the problem ?? Can anyone help me?
There's something wrong with your wiring or your software.
Or both.
"I have used all the 12 pins of arduino (from 2 to 13)."
You still have 14 to 19 left as well (aka A0 to A5).
As AWOL indicates, not enough info provided. Post all your code, a schematic, the motor types used, and the power source for the motor.
Dear,
I am using the digital pins 2 to 13. Sorry for the short post but I have some problem to share all code as I need permission from my supervisor.
The source used here for the motor is 48 V battery which is used in electric vehicle. If you require more then I can send it via email. I have some doubt about using of pin 13.
Power of the motor 500 W and voltage 48 V.
If anybody can find the solution, please respond asap.
