Problem with PZEM-004t CT sounds like creak when hooked onto cable
I am using PZEM-004 CT 100A sounds like a creaking sound when connected to a cable with a current below 10A.
I haven't connect it to PZEM. Could you let me know what's the problem is?
You could check my video in this link WhatsApp Video 2025-03-23 at 14.22.31 (1).mp4 - Google Drive
Thank you in advance
I moved your topic to an appropriate forum category @pa3461163
In the future, when creating a topic please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
how are you connecting the PZEM-004 CT 100A?
you must use the CT current clamp which comes with the module even for loads less than 10amp
a different module, the PZEM-004 10A, supports direct connection to the load
I have already use ct come from the pzem. You could check in my link video.
I will make a photo and share again soon
draw a schematic showing how everything is connected?
I haven't connected to any circuit, only hooked the CT on 10A cable. Photo attached
you should not leave a CT (Current Transformer) secondary without a load - it can generate a very high voltage (see The Current Transformer)
the "creaking sound" you reported in post 1 was probably due to this high voltage being generated when the load was switched on
ALWAYS connect a CT to a burden resistor or measuring device if the load is activated
That's likely the problem.
The CT must be connected to the circuit board, that has the matching burden resistor on it.
The coil itself generates very high (arching/sparking) voltages without that burden resistor.
Leo..
