I use a USBAsp programmer (though have had no problems with USBTinyISP or ArduinoAsISP - the only problem with the latter is that there are more wires to connect incorrectly), and a 2x3 ISP header on the board with the ATtiny on it. Any of those three programmers can be had (or made, in the case of arduino as ISP) for under $5 from ebay. Every time I have omitted an ISP header from a design, in the expectation of programming the parts before I solder them down, I've regretted it when I needed to change the firmware later. You don't need to actually install the pin header - you can stick 2x3 male pins into the connector on the controller, and hold in in place at an angle while programming, or use a 2x3 pogopin adapter.
For external components on a classic AVR (and, for that matter, the megaavr attinys), you need:
A 0.1uF ceramic cap between Vcc and Gnd. This should be located as close to the attiny as possible. If the part has more than 1 Vcc pin, ideally each should get a 0.1uF cap as close to the Vcc pin and it's adjacent Gnd pin as possible (though the length of the traces is typically not long enough that this is strictly necessary - most pro mini clones use only a single decoupling cap, for example). The t85 has only one Vcc pin, so only one decoupling cap is required.
If (and only if) you are using a part with an AVcc pin (most ATtinys do not have this, most ATmegas do), you need a 0.1uF cap on it like it's a Vcc pin.
If the wires from the power supply are long and/or the power supply is suspected to have poor transient response, include an additional capacitor between positive rail of supply (Either Vcc, or Vin if you've got a regulator on the board) and Gnd somewhere on the board. 10uF is generally a good choice here.
If you are using a regulator on the board, you must include capacitors on the input and output of the regulator, in addition to any others. The datasheet for the regulator will specify what kind of capacitors are suitable for this - some regulators are picky not only about the capacitance, but the ESR or capacitor type (which is short-hand for the ESR, as the ESR depends strongly on the type of capacitor).
If (and only if) you are using an external crystal as clock source (unlikely on the x5 series, more likely on parts with more pins), you need the crystal and appropriate loading caps (other side of loading caps goes to ground) on the crystal pins. You generally want the capacitance of the loading caps to be a few pF lower than the spec'ed capacitance of the crystal to allow for parasitic capacitance on the traces to the crystal. When using solderless breadboard, depending on the make and model of the breadboard, the parasitic capacitance alone may be sufficient for the crystal to work, and adding the loading caps may prevent it from working (resulting in it getting signature of 0x000000 after you "burn bootloader" to set fuses; in this case, the loading caps should be omitted (the loading caps are required when not using solderless breadboard). These must be placed as close as possible the crystal pins.
If you have long wires/traces on the Reset pin, put a 10K resistor between Vcc and Reset for noise rejection. If you are using the DTR auto-reset circuit to reset the part when a serial port is opened (eg, to enter a serial bootloader, or to restart the sketch from the beginning upon opening a serial port so you can see all the output), you also need this 10k resistor (but there should never be more than one such resistor).
If (and only if) you are using the DTR auto-reset circuit mentioned above, you also need a diode between Reset and Vcc (band towards Vcc), and a 0.1uF ceramic cap between DTR of adapter and Reset.
