I’m currently working on a project in which I need to power and control the fade level of five LEDs running in parallel at 700mA/1.5W. I’ll be using an external 150-1500mA buck regulator LED Driver (PS-SP12144), powered by a 12v/1000mA PSU. The LED driver takes a PWM that can regulate the LED connect to the LED driver. Here’s a short description of the pin layout:
Pin Description
VIN Positive terminal for 9V -48V DC Power supply
GND Power Ground
LED+ Positive of LED terminal
LED- Negative of LED terminal
EN PWM terminal. When applied with ground or suspended, full amount of current will be output and when connected with +5v or VIN, output current will be 0.
I’ll be using an Arduino Uno (first revision) to control the pwm through the analogWrite function, but for whatever reason, nothing happens when I PWM the EN pin.
Here's a picture of my setup:
I've used PWM signals many times in arduino projects, but I just can't get my head around this issue. If I connect the LED driver en PIN to VCC, then the light turns off.
The picture isn't very good.
Your Uno has a small black wire to the GND pin and it's impossible to see where the other small black wire goes.
Is it in a PWM pin at all ?
Is the first wire from GND connected to that green wire, and where does that one go ?
By the way, the description of that PWM input shows that is is reversed PWM.
That means a larger duty cycle will lead to more dimming, not more illumination.
You want to keep that in mind while creating your sketch.
