Hello!
I have read several threads about this, but I don't fully understand any of them..
Can I convert Arduino PWM to 0-10V with only using this device PWM to Analog (0-10V) Converter Module - Opencircuit ?
Use analogWrite(x); where x is a value 0 - 255, 0 being 0 volts, 128 being 5V and 255 being 10V, or
analogWrite(x*25.5); where x is the voltage required.
missdrew:
So I only need the component i linked? Not rc filters or op amps?
Correct! Other than a 12V - 30V Psu.
Will this also work? VMA409: L298N DUAL BRIDGE DC & STEPPER MOTOR CONTROLLER BOARD – Velleman – Wholesaler and developer of electronics
Yes, it will work. But might not for the task you have not told us about.
haha, my bad!
I want to control a 0-10vDC valve
not PWM, is wire, but is 12bit.
https://store.ncd.io/product/1-channel-0-10v-dac-digital-analog-converter-i²c/
used the above board to control a number of VFD with sweet results.
missdrew:
I see that the converter uses 1-3KHZ, but my arduino uno can give 980hz.
How do I fix this?
980Hz is 1kHz, to within a reasonable aproximation. However if it is fussy there are PWM libraries
that allow changing the Arduino PWM frequency.
I found several basically the same design. They state 1Khz minimum PWM frequency. The Arduino outputs I believe 960 on two of the pins by default. I think the worse thing is you will get a little ripple in the output. If it is a problem you can add some capacitance to the output or change the PWM frequency.
MarkT:
Ok, could you show me?
