I've recently bought a Makeblock XY plotter with the laser kit. After getting used to to the platform, i've ordered a more powerful laser to replace the stock one.
The old laser was a 500mW laser which ran at 6 volts. The new one is a 2.5w at 12 volts.
The motor output of the makeblock orion board (UNO based) spits out 12v PWM so in theory i should be able to connect the new laser to the motor output directly and control the ouput via software.
Only thing is when i hook the output to the scope i see some peaks on the signal like this: (i drew it from memory)
The Vpp is around 15 volts. the peaks is only momentarily but i'm a little concerned that it might damage the laser or its driver.
Is this an acceptable signal? Or should regulate or filter this to be safe?
Confused.. Are you talking about connecting the actual motor and laser on the same output? Why would you do that? The spikes you see are from the motor inductance.
Sometimes there is ringing caused by the scope probe, or it could be capacitance/inductance somewhere else in the circuit. ...You rarely see a perfect pulse on a scope, and you rarely need a perfect pulse. But of course, there are cases where a "bad" pulse or a bad/noisy clock can cause trouble.
You can't normally dim/control a laser with PWM on the power supply.
DVDdoug:
You are right, the power supply PWM didn't work. The laser either works at 100% or not at all.
Did you figure out what the T+ and T- are for? I had a poke around but didn't have enough time to figure our if they do anything.
I want to control my laser via TTL really so the fan is running constantly (and PWM the 12v supply, while it works, is not a good solution in my opinion - the spikes you see are probably caused by the inductance of the fan)
smremde:
