Hello, I've done a lot of stalking around the forums. But this is the first time I've registered to actually ask a question.
If I use two load cells like so:
- Can I wire together the identical wires from two of the load cells from 8 into 4 THEN connect it to the load cell amplifier HX711? If no, how can I go about doing that without 'combinator's.
- Would it increase the error % if I use two of them like this?
- Sounds kind of obvious, sorry, but if the maximum load is 10kg per load cell, would using two like this make the maximum 20kg?
Thank you.
