Raspberry Pico to Arduino ide
Hi all I am very newbie and want to play with barker code my question is it possible to turn this sketch to Arduino IDE
# Over-engineered dual core light barrier
# If the Raspberry Pi Pico already has two cores,
# why not use both for a light barrier with Barker-
# coded pulse sequences and autocorrelation?
# Hague Nusseck @ electricidea
# v1.0 | 27.December.2022
# https://github.com/electricidea/pico_light_barrier
# Check the complete project at Hackster.io:
# https://www.hackster.io/hague/over-engineered-dual-core-light-barrier-c523a9
# Distributed as-is; no warranty is given.
from machine import Pin,PWM,ADC
import utime
import _thread
led = Pin(20, Pin.OUT)                     # led connect to D20
light_sensor = ADC(2)                      # light sensor connected to A2
pwm = PWM(Pin(27))                         # buzzer connected to A1
pwm.freq(10000)
# Length and frequency of the sampling of the light sensor
n_samples = 75                             # number of samples captured from light sensor
sample_freq = 5000                         # sample frequency in Hz (5kHz are recommended)
dt_samples = (1 / sample_freq) * 1000000   # resulting time between two samples in microseconds
Barker_Code = [ 1.0,  1.0,  1.0,  0.0,  0.0,  0.0,  1.0,  0.0,  0.0,  1.0,  0.0] # length 11
# calculate the length of one "Barker Pulse" based on the length
# of the sampling window.
# The length is calculated by the number of pulses of the Barker Code
# plus 2 additional pulses (larger sampling window, shorter LED sequence)
pulse_length = n_samples // (len(Barker_Code)+2)
# generate the Barker Code as an array with the timing of
# the sampling frequency for the autocorrelation
n_Barker_Code_samples = len(Barker_Code)*pulse_length
Barker_Code_samples = [0.0] * n_Barker_Code_samples
for n in range(len(Barker_Code)):
    for i in range(pulse_length):
        Barker_Code_samples[n*pulse_length+i] = Barker_Code[n]
# increase the sampling windows by some "Barker Pulses" to create
# enough room for shifting for the autocorrelation
n_samples = n_samples + round(len(Barker_Code)/5)*pulse_length
# data array to store the measured sample data
data = [0.0] * n_samples
# array to store the sums of the auto correlation
n_autocorr = n_samples - n_Barker_Code_samples
autocorr = [0.0] * n_autocorr
autocorr_valid_window = [round(n_autocorr * 0.2), n_autocorr-round(n_autocorr * 0.2)]
# This wait function is not waiting for a fix number of ticks
# it is waiting until the actual tick-value (in microseconds)
# reaches the sum of the start-value and the add-value.
# With this method, a more precise pulse generation and
# sampling timing can be reached without adding up errors
# The functions utime.ticks_add() and utime.ticks_diff() are
# used to prevent value overflow problems with tick variables.
def wait_until_ticks(start_ticks, add_ticks):
    wait_time = utime.ticks_add(start_ticks, round(add_ticks))
    while utime.ticks_diff(wait_time, utime.ticks_us()) >= 0:
        pass
# The LED should be pulsed in its own task on the second core
# so we need a own function to switch the LED on and off to
# generate the light pulse pattern
def led_task():
    led.value(False)
    led_start_ticks_us = utime.ticks_us()
    # wait two pulse lenghts before start sequence
    wait_until_ticks(led_start_ticks_us, 2*pulse_length*dt_samples)
    for n, led_on_off in enumerate(Barker_Code):
        if led_on_off > 0:
            led.value(True)
        else:
            led.value(False)
        wait_until_ticks(led_start_ticks_us, (n+3)*pulse_length*dt_samples)
    led.value(False)
# simple buzzer-beep function
def beep(freq, duration=0.125):
    pwm.freq(freq)
    pwm.duty_u16(10000)
    utime.sleep(0.125)
    pwm.duty_u16(0)
# function to start the pulse generation an the measurement
# of the data from the light sensor
# the measured values are scaled from 0..0xFFFF to 0..1
# return value: minimum of all measured values
def measure():
    # the minimum value is used to compensate the offset
    # during the autocorrelation calculation
    light_val_min = 0xFFFF
    # start the led pulse generation on the second core
    _thread.start_new_thread(led_task, ())
    for n in range(n_samples):
        light_val = light_sensor.read_u16() / 0xFFFF
        data[n] = light_val
        if light_val < light_val_min:
            light_val_min = light_val
        wait_until_ticks(start_ticks_us, (n+1)*dt_samples)
    return (light_val_min)
# function to calculate the autocorrelation between the pulse signal
# and the measured light sensor data
# the minimum value is used to compensate the offset of the measurement
def autocorrelation(_min_val):
    autocorr_threshold = 0.75
    autocorr_max = -1000
    autocorr_max_pos = 0
    detection_state = 1
    signal_detected = False
    for shift in range(n_autocorr):
        autocorr[shift] = 0
        for pos in range(n_Barker_Code_samples):
            autocorr[shift] += Barker_Code_samples[pos] * (data[pos+shift]-_min_val)
        # detection state 1: looking for maximum
        if detection_state == 1:
            if autocorr[shift] > autocorr_max:
                autocorr_max = autocorr[shift]
                autocorr_max_pos = shift
            # When a falling curve is detected and max is within the valid range and position
            if (autocorr[shift] < autocorr_max) and ((autocorr_max - autocorr[0]) > autocorr_threshold) and (autocorr_max_pos >= autocorr_valid_window[0]):
                if autocorr_max_pos > autocorr_valid_window[1]:
                    detection_state = 3
                else:
                    detection_state = 2
        # detection state 2: check for valid falling curve
        if detection_state == 2:
            if (autocorr[shift] < (autocorr_max - autocorr_threshold)):
                signal_detected = True
                detection_state = 3
    #print(light_val_mean, autocorr_max, autocorr_max_pos)
    return (signal_detected)
# main loop
while True:
    if not autocorrelation(measure()):
        beep(800)
Or how to build same project using raspberry Pico using Arduino IDE if it's possible?
Simple answer is no, because that is Python and Arduino IDE uses C++. Of course, you can write C++ code to do the same thing.
If you use Micropython, there is no need for the Arduino IDE, so that doesn't really make sense.
Why do you think the Arduino IDE will help you?
Thanks for your response because that I am familiar with Arduino IDE
The Arduino IDE is to write C++ programs with specific extensions for use on an Arduino.
It doesn't understand Python and I don't think it can produce compiled code that can be run on a Pi.
It simply are two very different things.
