Troubles uploading sketch
Since today I experience problems uploading a sketch on Mac:
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/private/var/folders/tm/pcc8wkrd1sb64txkf5kxbmx40000gn/T/AppTranslocation/9837C28C-B563-4DCD-A28B-8F45CD81B20E/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/private/var/folders/tm/pcc8wkrd1sb64txkf5kxbmx40000gn/T/AppTranslocation/9837C28C-B563-4DCD-A28B-8F45CD81B20E/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodemFD131 -b115200 -D -Uflash:w:/var/folders/tm/pcc8wkrd1sb64txkf5kxbmx40000gn/T/arduino_build_92180/sketch_nov06a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/private/var/folders/tm/pcc8wkrd1sb64txkf5kxbmx40000gn/T/AppTranslocation/9837C28C-B563-4DCD-A28B-8F45CD81B20E/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/michiellampe/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodemFD131
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
An error occurred while uploading the sketch
What board?
Is the correct board selected? Is it a nano? if so, have you tried the "old bootloader" option from tools -> processor?
Is anything connected to pins 0, 1 or reset? If so disconnect it.
Did the board ever work? Do other boards work? If it previously worked, what did you do to it when it stopped working?
