Hi guys, I'm fairly new to coding and I've been playing with a capacitive touch instructable http://www.instructables.com/id/Touche-for-Arduino-Advanced-touch-sensing/ . I'm looking to modify the code so that I can connect another capacitive sensing circuit to my analog pin1 as the first input is on analog pin0. The Arduino code I'm currently working with is:
// Illutron take on Disney style capacitive touch sensor using only passives and Arduino
// Dzl 2012
// 10n
// PIN 9 --[10k]-+-----10mH---+--||-- OBJECT
// 3.3k |
// | V 1N4148 diode
// GND |
//Analog 0 ---+------+--------+
// 100pf 1MOmhm
// GND GND
#define SET(x,y) (x |=(1<<y)) //-Bit set/clear macros
#define CLR(x,y) (x &= (~(1<<y))) // |
#define CHK(x,y) (x & (1<<y)) // |
#define TOG(x,y) (x^=(1<<y)) //-+
#define N 160 //How many frequencies
float results[N]; //-Filtered result buffer
float freq[N]; //-Filtered result buffer
int sizeOfArray = N;
TCCR1A=0b10000010; //-Set up frequency generator
TCCR1B=0b00011001; //-+
ICR1=110;
OCR1A=55;
pinMode(9,OUTPUT); //-Signal generator pin
pinMode(8,OUTPUT); //-Sync (test) pin
for(int i=0;i<N;i++) //-Preset results
results[i]=0; //-+
unsigned int d;
int counter = 0;
for(unsigned int d=0;d<N;d++)
int v=analogRead(0); //-Read response signal
CLR(TCCR1B,0); //-Stop generator
TCNT1=0; //-Reload new frequency
ICR1=d; // |
OCR1A=d/2; //-+
SET(TCCR1B,0); //-Restart generator
results[d]=results[d]*0.5+(float)(v)*0.5; //Filter results
freq[d] = d;
// plot(v,0); //-Display
// plot(results[d],1);
// delayMicroseconds(1);
PlottArray(1,freq,results);
TOG(PORTB,0); //-Toggle pin 8 after each sweep (good for scope)
byte yMSB=0, yLSB=0, xMSB=0, xLSB=0, zeroByte=128, Checksum=0;
void SendData(int Command, unsigned int yValue,unsigned int xValue){
y = 01010100 11010100 (x & y are 2 Byte integers)
yMSB yLSB send seperately -> reciever joins them
yLSB=lowByte(yValue);
yMSB=highByte(yValue);
xLSB=lowByte(xValue);
xMSB=highByte(xValue);
Only the very first Byte may be a zero, this way allows the computer
to know that if a Byte recieved is a zero it must be the start byte.
If data bytes actually have a value of zero, They are given the value
one and the bit in the zeroByte that represents that Byte is made
high.
zeroByte = 128; // 10000000
if(yLSB==0){ yLSB=1; zeroByte=zeroByte+1;} // Make bit 1 high
if(yMSB==0){ yMSB=1; zeroByte=zeroByte+2;} // make bit 2 high
if(xLSB==0){ xLSB=1; zeroByte=zeroByte+4;} // make bit 3 high
if(xMSB==0){ xMSB=1; zeroByte=zeroByte+8;} // make bit 4 high
Calculate the remainder of: sum of all the Bytes divided by 255
Checksum = (Command + yMSB + yLSB + xMSB + xLSB + zeroByte)%255;
if( Checksum !=0 ){
Serial.write(byte(0)); // send start bit
Serial.write(byte(Command)); // command eg: Which Graph is this data for
Serial.write(byte(yMSB)); // Y value's most significant byte
Serial.write(byte(yLSB)); // Y value's least significant byte
Serial.write(byte(xMSB)); // X value's most significant byte
Serial.write(byte(xLSB)); // X value's least significant byte
Serial.write(byte(zeroByte)); // Which values have a zero value
Serial.write(byte(Checksum)); // Error Checking Byte
void PlottArray(unsigned int Cmd,float Array1[],float Array2[]){
SendData(Cmd+1, 1,1); // Tell PC an array is about to be sent
delay(1);
for(int x=0; x < sizeOfArray; x++){ // Send the arrays
SendData(Cmd, round(Array1[x]),round(Array2[x]));
//delay(1);
SendData(Cmd+2, 1,1); // Confirm arrrays have been sent
From reading the code I can see that digital pin9 is sending a signal which is reduced when you touch the plant and is tested against a solid signal at pin8, and the new data is stored in filtered and unfiltered arrays. I'm quite new to coding and I get lost when the x and y MSB LSB and byte related things are going on. If anyone could give me some input or a clue as to what I might need to add the help would be greatly appreciated!
