reading udp enc28j60
hi folks i'm using an arduino nano with enc28j60 ethernet shield, I have the following sketch up and running but need to read the data in a different format, I also have an arduino uno with a wiznet 5100 using the ethernet library but that isnt supported on the enc28j60.
Aaaaanyway long story short i have a char array in the uno sketch that gets populated via UDP and that i ll working fine, the problem I get is when i read the values in the data in the uno array is completely different to the array Ethernet::buffer in the nano sketch (shown below)
in the uno i create a char array and use udp.read to populate the array, how would I get the ame results in the sketch below?
// Demonstrates usage of the new udpServer feature.
//You can register the same function to multiple ports, and multiple functions to the same port.
// 2013-4-7 Brian Lee <cybexsoft@hotmail.com>
#include <EtherCard.h>
#include <IPAddress.h>
#define STATIC 0  // set to 1 to disable DHCP (adjust myip/gwip values below)
#if STATIC
// ethernet interface ip address
static byte myip[] = { 192,168,0,200 };
// gateway ip address
static byte gwip[] = { 192,168,0,1 };
#endif
char datain[768];
// ethernet mac address - must be unique on your network
static byte mymac[] = { 0x70,0x69,0x69,0x2D,0x30,0x31 };
byte Ethernet::buffer[768]; // tcp/ip send and receive buffer
//callback that prints received packets to the serial port
void udpSerialPrint(word port, byte ip[4], const char *data, word len) {
   IPAddress src(ip[0], ip[1], ip[2], ip[3]);
  Serial.println(data);
void setup(){
  Serial.begin(57600);
  Serial.println("\n[backSoon]");
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println( "Failed to access Ethernet controller");
#if STATIC
  ether.staticSetup(myip, gwip);
#else
  if (!ether.dhcpSetup())
    Serial.println("DHCP failed");
#endif
  ether.printIp("IP:  ", ether.myip);
  ether.printIp("GW:  ", ether.gwip);
  ether.printIp("DNS: ", ether.dnsip);
  //register udpSerialPrint() to port 1337
  ether.udpServerListenOnPort(&udpSerialPrint, 6454);
  //register udpSerialPrint() to port 42.
  ether.udpServerListenOnPort(&udpSerialPrint, 42);
void loop(){
  //this must be called for ethercard functions to work.
  ether.packetLoop(ether.packetReceive());
