Hey everyone Im new to this and struggling to understand what I need to do to solve this problem.
I'm using IDE 2.3.2.
The IDE is able to automatically select the correct port (the only port on my comp). I Selected Arduino Nano. See image
I get this using any of the processor options
Sketch uses 1880 bytes (6%) of program storage space. Maximum is 30720 bytes.
Global variables use 188 bytes (9%) of dynamic memory, leaving 1860 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\\.\COM3": Access is denied.
Failed uploading: uploading error: exit status 1
Do you have the serial monitor open on that port? Or a terminal program of some sort?
opened 07:07AM - 23 Dec 22 UTC
conclusion: resolved
topic: code
type: imperfection
### Describe the problem
In order to upload to an Arduino board via a serial β¦ port, the upload tool (e.g., [**AVRDUDE**](https://github.com/avrdudes/avrdude)) must be able to open the port. This is not possible if another process already has control of the port.
Arduino IDE's "Serial Monitor" and and "Serial Plotter" components also use the serial port of the board. Arduino IDE handles this potential conflict of port usage automagically by closing the port in Serial Monitor/Plotter when an upload process is triggered, then opening it again after the upload is finished. This means no special action is needed from the user to upload while Serial Monitor/Plotter is open.
π The upload fails with an "`Access is denied`" error under the following conditions:
- The board uses an FTDI FT232R USB chip
- Arduino IDE is running on a Windows machine
- Serial Monitor or Serial Plotter is open
I've been using Arduino IDE 2.0.3 with Nano without issues when uploading on Ubuntu. Now I've tried it on Windows 11, and most of the time, it gives me this error:
```text
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\macie\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\\.\COM5": Access is denied.
But I can see logs from the serial monitor in Arduino IDE -> serial monitor.
### To reproduce
#### Equipment
A board or other device that has an [FTDI FT232R USB chip](https://ftdichip.com/products/ft232rl/)
The [classic **Arduino Nano**](https://docs.arduino.cc/hardware/nano) is a common board that uses this chip.
FT232R modules ([example](https://docs.arduino.cc/retired/other/usb-serial-converter)) or cables ([example](https://www.sparkfun.com/products/9717)) are also often used to upload to boards such as the [**Arduino Pro Mini**](https://www.sparkfun.com/products/11113) that don't have an integrated USB chip.
The fault can be reproduced even if the FT232R-based device is not an Arduino board. In this case, the upload is expected to fail, but it would fail with a "`not in sync`" error instead of "`Access is denied`".
#### Steps
1. Select **File > New Sketch** from the Arduino IDE menus.
1. Connect the Arduino board to your computer.
1. Select the board and port from the Arduino IDE menus.
1. If the Serial Monitor view is not already open, select **Tools > Serial Monitor** from the Arduino IDE menus to open it.
1. Select **Sketch > Upload** from the Arduino IDE menus.
1. Wait for the upload process to finish.
π The upload fails:
```text
Using Port : COM5
1. Click the **X** icon on the "**Serial Monitor**" view tab in the bottom panel.
π The upload is successful.
1. Select **Tools > Serial Plotter** from the Arduino IDE menus.
π The upload fails:
```text
Using Port : COM5
1. Close the "**Serial Plotter**" window.
π The upload fails:
```text
Using Port : COM5
**β** This unexpected result is caused by a separate bug: https://github.com/arduino/arduino-ide/issues/1423
### Expected behavior
Serial Monitor and Serial Plotter do not interfere with upload process.
### Arduino IDE version
#### Original report
2.0.3
#### Last verified with
aa9b10d
### Operating system
Windows
### Operating system version
Edition Windows 11 Pro
Version 22H2
Installed on 07/11/2022
OS build 22621.963
Experience Windows Feature Experience Pack 1000.22638.1000.0
### Additional context
I bisected the introduction of the fault to df8658e
Logs generated from an upload that fails with this fault using the build for 053574b with the `arduino.cli.daemon.debug` [advanced setting](https://github.com/arduino/arduino-ide/blob/main/docs/advanced-usage.md#advanced-settings) set to `true`:
[2023-08-16_log.log](https://github.com/arduino/arduino-ide/files/12357046/2023-08-16_log.log)
I have no problems uploading sketches on Arduino IDE 1.8.19 from Microsoft Store on the same system. I can quit 2.0.3, start 1.8.19, and it's working immediately.
I cannot reproduce the fault on Linux (Ubuntu 22.04) or macOS (Ventura).
I cannot reproduce the fault when using native USB boards (e.g., [**Leonardo**](https://docs.arduino.cc/hardware/leonardo), [**MKR**](https://docs.arduino.cc/#mkr-family)) or boards that use other models of dedicated USB chip (e.g., ATmega16U2 on Uno and Mega, WCH CH340 on derivative boards).
<a name="workaround"></a>
#### Workaround
<a name="serial-monitor"></a>
##### Serial Monitor
1. Click the **X** icon on the "**Serial Monitor**" tab in the bottom panel of the Arduino IDE window to close the tab:
1. Upload the sketch.
1. Open **Serial Monitor** again if needed (by clicking the icon on the IDE toolbar or the **Tools > Serial Monitor** menu item) after the upload is finished.
<a name="serial-plotter"></a>
##### Serial Plotter
1. If the "**Serial Monitor**" view is not already open, select **Tools > Serial Monitor** from the Arduino IDE menus to open it.
**β** We must do an open/close cycle on **Serial Monitor** as a workaround for [a bug](https://github.com/arduino/arduino-ide/issues/1423) in **Serial Plotter**
1. Open **Serial Monitor** and/or **Serial Plotter** again if needed after the upload is finished.
#### Additional reports
- https://github.com/arduino/arduino-ide/issues/1937
- https://github.com/arduino/arduino-ide/issues/726#issuecomment-1464313325
- https://github.com/arduino/arduino-ide/issues/1783#issuecomment-1614370292
- https://forum.arduino.cc/t/brand-new-nano-wont-connect-to-latestide-software/1129473/10
- https://forum.arduino.cc/t/arduino-nano-not-able-to-upload-comx-port-access-denied/1081669/15
- https://forum.arduino.cc/t/elusive-uno-upload-error-access-is-denied/1067785/5
- https://forum.arduino.cc/t/fdti-breakout-2-types-cause-usb-acess-denial/1088005
- https://forum.arduino.cc/t/port-access-is-denied/1089761
- https://forum.arduino.cc/t/cant-open-device-when-uploading-but-serial-monitor-works/1127731
- https://forum.arduino.cc/t/2-1-0-no-longer-disables-monitor-during-upload-update/1139065
- https://forum.arduino.cc/t/access-denied-when-uploading-to-arduino-nano/1139330/1
- https://forum.arduino.cc/t/access-denied-when-uploading-to-arduino-nano/1139330/11
- https://forum.arduino.cc/t/2-11-com3-access-is-denied/1143750
- https://forum.arduino.cc/t/cannot-upload-to-arduino-nano/1145391
- https://forum.arduino.cc/t/cant-upload-to-pro-mini-port-access-is-denied/1152460
- https://forum.arduino.cc/t/cannot-upload-to-ftdi-megas-only/1170683
- https://forum.arduino.cc/t/arduinon-nano-access-denied/1181808/6
- https://forum.arduino.cc/t/avrdude-ser-open-cant-open-device/1228096
- https://forum.arduino.cc/t/avrdude-ser-open-cant-open-device-com9-access-is-denied/1205151
- https://forum.arduino.cc/t/exit-status-1-only-sometimes/1180375
- https://forum.arduino.cc/t/have-to-kill-serial-monitor-exe-to-upload-to-the-board/1173764
- https://forum.arduino.cc/t/arduino-nano-not-recognised-correctly/1133051
- https://forum.arduino.cc/t/arduino-nano-avrdude-ser-open-cant-open-device-com5-access-is-denied/1124189
- https://forum.arduino.cc/t/i-have-a-problem-while-uploading-to-arduino-pro-mini/1255072
- https://forum.arduino.cc/t/problem-uploading-to-nano/1267124
- https://forum.arduino.cc/t/nano-appears-as-com6-and-doesnt-work/1273314
- https://www.reddit.com/r/arduino/comments/1bhwt6f/access_is_denied_error_on_nano/
#### Related
- https://forum.arduino.cc/t/issue-with-flashing-esp32-dev-kit-with-arduino-ide/1117755
- https://forum.arduino.cc/t/port-issues-with-ide-2-0-3/1069090
### Issue checklist
- [X] I searched for previous reports in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the problem still occurs when using the latest [nightly build](https://www.arduino.cc/en/software#nightly-builds)
- [X] My report contains all necessary details
Hey thank you that link. I tried to follow the steps but this is what appeared when i open the Serial Monitor.
One thing I noticed between trying this last night, and then going to and trying this solution this morning. the COM port changed from 3 to 4. I only have one on my computer, could this be related?
Did you plug your USB cable into a different USB port on the computer?
jim-p
June 28, 2024, 11:25am
5
What operating system are you using? Windows 7,8,10,11, Mac, Linux?
Is your nano a clone?
Im running Windows 11. this is my nano board (I got it second hand) I'm not sure what a clone is.
jim-p
June 28, 2024, 12:20pm
8
Clone is any board that is not a Genuine Arduino and I'm sure you have a clone.
Do you know if the board ever worked?
Disconnect all the wires from the board and try again.
I diconnected all the wire and it produced the same error. I also have this board which looks slightly different
which is showing this error code when i try to upload the code:
Sketch uses 1772 bytes (5%) of program storage space. Maximum is 30720 bytes.
"C:\Users\yazi_\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\yazi_\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM4" -b115200 -D "-Uflash:w:C:\Users\yazi_\AppData\Local\Temp\arduino\sketches\25A9BEB5BE98941D14ECE771C483B521/sketch_jun26a.ino.hex:i"
System wide configuration file is "C:\Users\yazi_\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0
avrdude done. Thank you.
jim-p
June 28, 2024, 12:34pm
10
That is a completely different error. Usually indicates a bad connection between the computer and the board, or the board has a problem. Try a different USB cable. Make sure it is NOT a charging only cable.
Does the power led light?
Does the 'L' LED blink when you first plug in the board?
Make sure all those wires are disconnected
Another tip:
Some of the most recent sold Nano Clone boards do not need anymore to select "old bootloader" option. You can try using the regular bootloader option.
xfpd
June 28, 2024, 6:06pm
12
I think this needs emphasis... and verification.
2112
June 28, 2024, 6:34pm
13
You may need to install the CH340 driver. Do you have the CH340 chip on the bottom side of your Nano and is the driver installed?
Follow this
