For magnet wire, I just use a utility knife and scrape backwards while rotating the wire each way. There are also auto scraper tools available and chemical solutions. Note that there are different types of coatings, each having their own characteristics and degree of difficulty for removal.
How will you solder to it then? Won't that melt the wire also?
Perhaps the wire is intended to go in some kind of socket that holds it on place with compression?
CrossRoads:
Copper melts at about 1000oC, butane+air burns at about 2000oC. Good luck finding a soldering iron that can match those temps.
And also, soldering tips are themselves made of copper. It would be pretty impossible to make a soldering iron melt a copper wire without melting the whole iron first.
Whenever I've used a lighter to burn the enamel off, it changes the wire so it breaks more easily.
Just use a soldering iron with rosin core 63/37 solder. It will take a little bit longer than soldering a bare wire, but it should just melt the enamel off.
