Here is my adapted code for the JsxzLz RFID reader I bought from Ebay (RFID 125Khz Module Kit with module, antenna, 3 TAGs).
Here is a picture of the reader:
And here is the code:
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arudino by djmatic
// Re-Modified for Arduino and 125Khz JsxzLz RFID Kit from Ebay by Biohazard
// RFID reader comes with 11 pins: D3 D2 D1 Rest Mcst Gnd L1 L2 PC TX VCC
// We need these to be connected:
// Rest to Arduino pin 2
// Gnd to Arduino GND
// L1 and L2 to the antenna
// TX to Arduino RX0
// VCC To Arduino 5V
int val = 0;
char code[14];
// 2 digits manufacture code
// 10 digits card code
// 2 digits parity bits
int bytesread = 0;
Serial.begin(9600); // RFID reader TX pin, Baud rate: 9600, Data bits: 8, stop bit: 1.
pinMode(2,OUTPUT); // Set digital pin 2 as OUTPUT to connect it to the RFID RESET pin
digitalWrite(2, HIGH); // Activate the RFID reader
if(Serial.available() > 0) { // if data available from reader
if((val = Serial.read()) == 10) { // check for header
bytesread = 0;
while(bytesread < 14) { // read 14 digit code
if( Serial.available() > 0) {
val = Serial.read();
if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 14) { // if 14 digit read is complete
Serial.print("TAG code is: "); // possibly a good TAG
Serial.println(code); // print the TAG code
bytesread = 0;
digitalWrite(2, LOW); // deactivate the RFID reader for a moment so it will not flood
delay(1500); // wait for a bit
Thanks for reading, have fun!
