i'm using in esp32 DOIT KIT V1 and i have RFID Reader also
pin conection
3.3v=3.3v
GND=GND
RST=D22
MOSI=D23
MISO=D19
SCK=D18
SDA=D21
Firmware Version: 0x0 = (unknown)
WARNING: Communication failure, is the MFRC522 properly connected?
I'm run in firmware check but not getting proper responce
please help me
Please post the full sketch that you have a problem with, using code tags when you do
* Example sketch/program to test your firmware.
* This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
* This example test the firmware of your MFRC522 reader module, only known version can be checked. If the test passed
* it do not mean that your module is faultless! Some modules have bad or broken antennas or the PICC is broken.
* @author Rotzbua
* @license Released into the public domain.
* Typical pin layout used:
* MFRC522 Arduino Arduino Arduino Arduino Arduino
* Reader/PCD Uno/101 Mega Nano v3 Leonardo/Micro Pro Micro
* Signal Pin Pin Pin Pin Pin Pin
* RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
* SPI SS SDA(SS) 10 53 D10 10 10
* SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
* SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
* SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
* More pin layouts for other boards can be found here: https://github.com/miguelbalboa/rfid#pin-layout
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 22 // Configurable, see typical pin layout above
#define SS_PIN 21 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
* Check firmware only once at startup
Serial.begin(115200); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 module
Serial.println(F("*****************************"));
Serial.println(F("MFRC522 Digital self test"));
mfrc522.PCD_DumpVersionToSerial(); // Show version of PCD - MFRC522 Card Reader
Serial.println(F("-----------------------------"));
Serial.println(F("Only known versions supported"));
Serial.println(F("Performing test..."));
bool result = mfrc522.PCD_PerformSelfTest(); // perform the test
Serial.print(F("Result: "));
if (result)
Serial.println(F("OK"));
Serial.println(F("DEFECT or UNKNOWN"));
void loop() {} // nothing to do
Some of those pin numbers sound wrong
My notes say that for the ESP32, the default SPI MOSI is pin 23, MISO 19, and SCK pin 18
Did you by any chance edit your original post and change the pin numbers that you gave, as I am sure that when I replied your pin numbers were wrong
nooooooooo i'm not edit my post
OK, then I am mistaken
Sorry
