I'm working on a project that uses a rotary encoder as input. I'm planning on using it later to interface to a menu.
For now, I'm just getting it to count up and down and detect when the button is pressed. I'm using hardware debouncing on the encoder based on this VIDEO
Sometimes when I reset the arduino and rotate the encoder clockwise (which should have the effect of increasing the value being printed to the lcd) the first value is -1, or it does not change from 0.
It seems all subsequent encoder movements read correctly, its just the first reading that's the problem.
Here is my code:
#define BUTTON_PIN 7
#include <LiquidCrystal.h>
int pulses, A_SIG = 0, B_SIG = 1;
int value = 0, lastPulses = 0;
boolean pulseChange = false;
boolean buttonState = false;
boolean lastButtonState = false;
LiquidCrystal lcd(8, 13, 9, 10, 11, 12);
attachInterrupt(0, A_RISE, RISING);
attachInterrupt(1, B_RISE, RISING);
pinMode(BUTTON_PIN, INPUT);
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
lcd.clear();
}//setup
lcd.setCursor(0, 0);
if (pulseChange == true) {
pulseChange = false; // if clockwise, increment counter
if (pulses > lastPulses) {
value++;
else if (pulses < lastPulses) { // if counterclockwise, decrement counter
value--;
lcd.print("Value = ");
lcd.print(value);
lastPulses = pulses; // save this for next time around
buttonState = digitalRead(BUTTON_PIN);
if (buttonState != lastButtonState)
Serial.println(buttonState);
lcd.print("Encoder = ");
lcd.print(value);
lcd.setCursor(0, 1);
lcd.print("Button : ");
lcd.print(buttonState);
lastButtonState = buttonState;
void A_RISE() {
detachInterrupt(0);
A_SIG = 1;
if (B_SIG == 0)
pulses++;//moving forward
pulseChange = true;
if (B_SIG == 1)
pulses--;//moving reverse
pulseChange = true;
//Serial.println(pulses);
attachInterrupt(0, A_FALL, FALLING);
void A_FALL() {
detachInterrupt(0);
A_SIG = 0;
if (B_SIG == 1)
if (B_SIG == 0)
void B_RISE() {
detachInterrupt(1);
B_SIG = 1;
if (A_SIG == 1)
if (A_SIG == 0)
attachInterrupt(1, B_FALL, FALLING);
void B_FALL() {
detachInterrupt(1);
B_SIG = 0;
if (A_SIG == 0)
if (A_SIG == 1)
