Anyone have any luck getting the RP2040 Nano Connect running on windows 7? I tried installing it from the Board Manager but it wont accept the driver. In Device Manager it shows up as RP2040 Nano Connect but has a red X. I browsed to the prewin10/arduino_mbed.inf file in the user AppData directory, but it wouldn't recognize that as a driver. I right clicked on that file and chose install, but the error message was 'The INF file you selected does not support this method of installation'.
Ok, good info. I think @pert has a lot of info on this as do many others. I'm sure someone will help soon enough.
Also, what version of the Arduino IDE please?
I followed these steps, but the driver still wouldn’t load. When I browsed and selected arduino_mbed.inf from the app data pre-win10 driver directory it only showed Nano iot 33 BLE.
@studiogamma Have you tried the steps in another computer? Are you using official Arduino Nano iot 33 BLE? If you use a bad USB cable, it will never connect (Use a data USB cable capable of 480Mbps and do not use a USB hub or USB 3.0 port.)
I'm using the RP2040 Connect, trying to install it on Windows 7.
I know its official I bought it on arduino.cc.
Also I did get it working perfectly on a Linux Mint desktop. I had to run the post_install to get it working. ( I also tried that with the Win7 with no luck).
Your system manager so we can see the version and build of Windows
What does it say when you click on the Driver not installed successfully
Please screenshot both of those.
It's apparent that your Nano is ok because the same Nano worked on another machine. Please be sure to use the same USB cable that worked with it on the other machine.
