Searching for 'GPS' module
I am going to search a 'GPS' module for my project but their are lots of module in similar price range,
Kindly please suggest me a GPS module having higher accuracy and high precision
(is any module supports NavIC?)
Price range - 2000 to 2500₹
Required to make project car having gps navigation
Higher than what? High precision will not come from your standard GPS system.
Higher in this price range🙂
Accuracy depends on the number of satellites that can be seen by your car, not the price of the module.
what I look for in a GPS module is:
at least two mounting holes, 3mm or 1/8"
an SMA antenna connector
one mounting hole is a pivot pint. two mounting holes is a rigid mount. 3 or 4 would be better
u.fl connectors are good only for attaching a jumper with an SMA connector
this is what I use:
The inexpensive modules all perform similarly, but beware of counterfeits (NEO-6M especially). https://portal.u-blox.com/s/question/0D52p00008cihGkCAI/fake-or-real-neo6m
My own observation is that GPS navigation apps on mobile phones achieve a higher level of accuracy than that provided by GPS by looking at your direction of travel and checking to see if it matches up with the surveyed road map provided by Google/Apple. If there is an offset in a particular direction it automatically subtracts that offset so that you path on the ground is over a marked road instead of being off to one side by a few meters.
