Send a contact closure
I've been working with a project where I need to trigger an external device to start listening for output from my Arduino. The external device uses a simple contact closure to trigger listening mode. I have tried setting a digital pin to High/LOW but the closure gets sensed immediately (before I send it). I have also tried this with an Analogwrite as well with similar results. I can make it work by collecting the closure from a push button, but I'd like my program to be able to send that signal without my pressing the button each time. I also have a small 5v DC relay from Radio Shack, but have not been able to figure out those connections either.
Any suggestions? I feel like this should be a simple thing, but I have a limited electronics background at best and I'm missing something.
Briarstomp
You have to be careful about making direct electrical connections from an Arduino to an another device which has not been specifically designed to operate with the Arduino.
If your 'external device' has contacts which are normally open and closing these causes the device to function, the safest way is to use the relay. There you connect the relay contacts in parallel with the contacts of the 'external device' (use the n/o normally open contacts).
How you wire the relay coil is dependent on the type of relay. In the simplest case, you connect this between an Arduino pin and ground. However, if the current required to drive the relay is more than around 20 mA, you need a transistor to switch it. Some relay modules have an inbuilt transistor switch.
Post a link to your relay for more information.
I assume the part I'm missing is the transistor. Here is the relay information and a layout for the pins. I appreciate the help and guess I need to go read up on transistors.
Relay Information:
Micro 1A SPDT Relay
(275-0240) Specifications Faxback Doc. # 45621
Contact Form: ....................................................... SPDT
Contact Gap: ..................................................... 0.15 mm
Contact Pressure: ....................... 3 grs. Min. at center of contact
Contact Capacity: ........................................... 125 VAC, 1 A
24 VDC, 1 A
Coil Voltage: ...................................................... 5 VDC
Min. Puck-Up Voltage: ........................................... 3.75 VDC
Nominal Coil Current: .............................................. 90 mA
Coil Resistance: .......................................... 55 Ohm +/- 10%
Operating Time: ............... 10 milli Seconds Max. at nominal condition
Release Time: .................. 5 milli Seconds Max. at nominal condition
Temperature Range: ................... -25 to +55 Degrees C. @ 60% RH Max.
Humidity Range: ...................... 95% RH Max. from 5 to 35 Degrees C.
Dimensions (HWD): .............................. 0.35 x 0.41 x 0.29 Inches
(9.0 x 10.3 x 7.3 mm)
You need a transistor because 90 mA exceeds the absolute maximum Arduino pin current capacity of 40 mA.
You should do something like this:
with the exception that you are using 5 volts and not 12 volts as in the illustration.
Example transistor 2n3904. Only the relay coil is shown, not the contacts it switches.
Thank you. To make sure I'm headed in the right direction.... The pin connects to the input side?
Exactly. The input is from an Arduino pin.
