Sensor for measuring sensitive touch
Hello
Im currently working on an Arduino based project, which involves a sensor that suppose to be sensitive to a soft touch and can't find an appropriate one.
Requirements:
1.sensitive for soft pressure.
2.flexible.
3.Resistance for wet and humid area.
4.as narrow as possible (it is supposed to fit on a narrow curved stripe).
5.a good and precise resolution.
I tried to use a softpot potentiometer, but it wasn't sensitive enough. I think that it's because the sensor is pressure based and maybe a non pressure based solution can achieve netter but since im not familiar with sensors so I would love to get an advice.
Im open to new concepts and ways of thinking about that.
Thank you very much
*Data sheet of the potentiometer I already tried to use:
SOFTPOT-DATA-SHEET
capacitive touch sensor?
What are you trying to sense? IE measure what exactly?
Touch/proximity or pressure?
Do you need to know the actual pressure applied?
How narrow is "narrow"?
"a good and precise resolution" - what is "good", what is "precise" and resolution of what?
