Servo control using Rx/Tx controller using arduino to channel the signal
Hey all,
I am trying to increase the throw of the servo that I can get using an independent Rx/Tx transmitter receiver set. This is the particular set: http://rotor.co.in/show-detail.asp?prodid={A1268AF3-5423-4B08-BFB7-E97DCD4A22B4}
I am using an Arduino Mega and the code that I am using is this:
#include <Servo.h>
#define throttlepin 21
#define throttlepinDIGITAL 21
#define motor1pin 4
#define motor2pin 5
#define motor3pin 6
#define motor4pin 7
#define motor5pin 8
#define motor6pin 9
#define servo1pin 2
#define servo2pin 3
#define newthrottle 1
#define newservo1 2
#define newservo2 4
volatile unsigned long starttime=0;
volatile unsigned long s1starttime=0;
volatile unsigned long s2starttime=0;
volatile int throttleinput, servo1input, servo2input;
volatile uint8_t check;
volatile int servo1val, servo2val;
Servo motor1;
Servo motor2;
Servo motor3;
Servo motor4;
Servo motor5;
Servo motor6;
 attachInterrupt(0, calcInput1Servo, CHANGE);
 attachInterrupt(1, calcInput2Servo, CHANGE);
 attachInterrupt(2, calcThrottle, CHANGE);
 motor1.attach (motor1pin);
 motor2.attach(motor2pin);
 motor3.attach(motor3pin);
 motor4.attach(motor4pin);
 motor5.attach(motor5pin);
 motor6.attach(motor6pin);
 Serial.begin(4800);
noInterrupts();
//Servo 2 Loop
 if (check & newservo2)
    Serial.print("servo_main");
    Serial.println(servo2input);
    if (servo2input>1700)
      servo2val= servo2input;
      servo2val = map(servo2val, 1700,2200, 0, 180);
      motor3.write(servo2val);
      Serial.print("servo1: ");
    Serial.println (servo2val);
    else if (servo2input<1690)
      servo2val = map(servo2val, 1200,1680, 0, 180);
      motor4.write(servo2val);
      //Serial.print("servo2: ");
    //Serial.println (servo2val);
    //check|=newservo2;
    //interrupts();
   if (check & newthrottle)
    //Serial.print("newthrottle: ");
    //Serial.println (throttleinput);
    motor5.write(throttleinput);
    motor6.write(throttleinput);
  //Servo 1 Loop
 if (check & newservo1)
   // Serial.print("servoi_main");
    //Serial.println(servo1input);
    if (servo1input>1490)
      servo1val= servo1input;
      servo1val = map(servo1val, 1490,1892, 0, 180);
      motor1.write(servo1val);
      //Serial.print("servoi1: ");
    //Serial.println (servo1val);
    else if (servo1input<1460)
      servo1val = map(servo1val, 1064,1460, 180, 0);
      motor2.write(servo1val);
      //Serial.print("servoi2: ");
  check=0;
  interrupts();
void calcInput1Servo(){
  noInterrupts();
  if (digitalRead(servo1pin)==HIGH) {
    s1starttime=micros();
  if(s1starttime)
    servo1input= (int) (micros()-s1starttime);
    check|=newservo1;
    s1starttime=0;
 interrupts();
void calcThrottle(){
  noInterrupts();
  if (digitalRead(throttlepin)==HIGH) {
    starttime=micros();
  if(starttime)
    throttleinput= (int) (micros()-starttime);
    check|=newthrottle;
    starttime=0;
 interrupts();
void calcInput2Servo()
 noInterrupts();
 if (digitalRead(servo2pin)==HIGH)
    s2starttime=micros();
 else  {
    servo2input= (int) (micros()-s2starttime);
    check|=newservo2;
 interrupts();
I followed the guide given here: RCArduino: How To Read Multiple RC Channels
I used the general concept behind the code given on this website to suit my needs. What i am actually trying to do is to pass the Rx signals through the Arduino and then given them to the servo so that i can get 180 degrees motion of the servo using only half deflection of the analog stick of the transmitter.
I presume there is something wrong with the code or is there something wrong with the concept behind the code.
Please help as I am in dire need of this.
Thanks
Summit
