Hi! I'm trying to create a simple script where my servo motor moves to a 90 degree position while the distance measured by a tfmini is <=5 and moves to 0 degrees otherwise.
This is the code that I have and I'm not too sure why it's not working. The motor is only essentially jittering back and forth in place.
I'm using an arduino uno.
#include <SoftwareSerial.h> //header file of software serial port
#include<Servo.h> // Servo Library
SoftwareSerial Serial1(0, 1); //define software serial port name as Serial1 and define pin0 as RX & pin1 as TX
// Define TFMini Variables
int dist; //actual distance measurements of LiDAR in cm
int strength; //signal strength of LiDAR
int check; //save check value
int i;
int uart[9]; //save data measured by LiDAR
const int HEADER = 0x59; //frame header of data package
// Define Servo Motor Control and Variables
Servo myservo; //Creating servo object to control the servo
int pos=0; // Angular position of servo motor
// TFMini Setup & Measurement Loop
Serial.begin(9600); //set bit rate of serial port connecting Arduino with computer
Serial1.begin(115200); //set bit rate of serial port connecting LiDAR with Arduino
myservo.attach(9); //Attaches servo object to pwm pin 9
if (Serial1.available()) //check if serial port has data input
if (Serial1.read() == HEADER) //assess data package frame header 0x59
uart[0] = HEADER;
uart[1] = HEADER;
for (i = 2; i < 9; i++) //save data in array
uart[i] = Serial1.read();
check = uart[0] + uart[1] + uart[2] + uart[3] + uart[4] + uart[5] + uart[6] + uart[7];
if (uart[8] == (check & 0xff)) //verify the received data as per protocol
dist = uart[2] + uart[3] * 256; //calculate distance value
strength = uart[4] + uart[5] * 256; //calculate signal strength value
Serial.print("dist = ");
Serial.print(dist); //output measure distance value of LiDAR
Serial.print('\t');
Serial.print("strength = ");
Serial.print(strength); //output signal strength value
Serial.print('\n');
while (dist < 10);{
myservo.write(90);
while (dist>5){
myservo.write(0);
