Hi, just wondering if this board can power 2 RC servos without melting down.
Thanks
Thanks
Hi @Kirwin ,
In general, the servo power consumes a lot of current.
What is the model of your servo.
RV mineirin
Hi.
Servos probably will be or equivalent to a TIANKONGRC MG995
AND A TIANKONGRC micro servo SG90.
Thank you
I’m hoping to avoid using a motor controller or the larger Uno board. The 2 servos will be mounted in a Halloween skull and the large servo turning the head and the micro servo opening and closing the jaw.
I’m hoping I can fit the board inside the skull so it needs to be small.
Power the servos from 6V battery (4 AA batteries).
Feed the battery 6V to a step up converter ( MT3608) set to 8V.
Feed the 8V to the Arduino Vin pin.
Use a boost converter like this:
Ok so that’s all need to drive the servos through the micro controller?
Thanks so much
Awsum!!! Thanks so much again
@Kirwin your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with your project (or questions about it)
See About the Installation & Troubleshooting category.
If your problem is solved or question answered you can click the solution checkbox under the most useful reply to let others know that it is solved.
Hi Larry,
Quick question. Just wondering why I need 8 volts to power 5 volt servos. What would happen if I just powered the servos directly through the 6 volt battery pack?
Thanks
LarryD's schematic in post #7 shows 6V going to the servos, not 8V. The 8V goes to the Vin of the Nano.
Yes thats right. Sorry. My bad. Thanks for pointing that out.
BTW
We use the Boost Converter to make 8V for the Arduino Vin pin.
As the batteries discharge (say to 5V) the Vin pin still remains at 8V, therefore the Arduino will not be starved when the battery voltage decreases.
Thanks for explaining it to me. Makes sense now.
Best wishes
