SIM808 Get GPS Problem
Hi everybody,
I just bought me a SIM808 board ( SIM 808 GPRS/GSM Modul mit GPS Antenne – AZ-Delivery ) and i am using the Arduino Uno Rev 3.
I want to check my location with this code:
### Get GPS data
1. This example is used to test SIM808 GPS/GPRS/GSM Shield's reading GPS data.
2. Open the SIM808_GetGPS example or copy these code to your project
3. Download and dial the function switch to Arduino
4. open serial helper
4. Place it outside, waiting for a few minutes and then it will send GPS data to serial
create on 2016/09/23, version: 1.0
by jason
#include <DFRobot_sim808.h>
#include <SoftwareSerial.h>
//#define PIN_RX    11
//#define PIN_TX    10
//SoftwareSerial mySerial(PIN_TX,PIN_RX);
//DFRobot_SIM808 sim808(&mySerial);//Connect RX,TX,PWR,
DFRobot_SIM808 sim808(&Serial);
  //mySerial.begin(9600);
  //******** Initialize sim808 module *************
  while(!sim808.init()) {
      Serial.print("Sim808 init error\r\n");
  //************* Turn on the GPS power************
  if( sim808.attachGPS())
      Serial.println("Open the GPS power success");
      Serial.println("Open the GPS power failure");
   //************** Get GPS data *******************
   if (sim808.getGPS()) {
    Serial.print(sim808.GPSdata.year);
    Serial.print("/");
    Serial.print(sim808.GPSdata.month);
    Serial.print("/");
    Serial.print(sim808.GPSdata.day);
    Serial.print(" ");
    Serial.print(sim808.GPSdata.hour);
    Serial.print(":");
    Serial.print(sim808.GPSdata.minute);
    Serial.print(":");
    Serial.print(sim808.GPSdata.second);
    Serial.print(":");
    Serial.println(sim808.GPSdata.centisecond);
    Serial.print("latitude :");
    Serial.println(sim808.GPSdata.lat);
    Serial.print("longitude :");
    Serial.println(sim808.GPSdata.lon);
    Serial.print("speed_kph :");
    Serial.println(sim808.GPSdata.speed_kph);
    Serial.print("heading :");
    Serial.println(sim808.GPSdata.heading);
    //************* Turn off the GPS power ************
    sim808.detachGPS();
When I upload it and run the SIM808 it sends me this:
AT
AT+CFUN=1
AT+CPIN?
AT+CGNSPWR=1
AT+CGNSTST=1
and thats all. Nothing more. Can someone help me?
Are you using Serial to talk to the SIM808? Or, are you using it to talk to the PC? Both is the wrong answer.
Where did you get the library you are using?
