Can anyone attest to the feasibility, reliability, ease of soldering etc for mounting a PCB onto another with a direct soldered connection? I've seen pictures but sometimes words are more important than pictures. I'd like to solder a promini to a larger PCB. I found custom short symmetric headers but they're expensive!
I've soldered them directly to and with headers on mother boards.
Headers are relatively inexpensive on eBay.
Solid AWG 24 would work.
The "round pin" style of headers are much shorter than the standard header pins. They're a little more expensive but not by much.
perigalacticon:
OK, so "expensive(!)" can be a relative term, but it is more likely that you simply aren't looking hard enough, or you haven't heard of clippers yet.
If you want the functionality of an arduino on a pcb you're designing, why not take the publiished pcb designs
and incorporate them into your board?
Allan
You can always just mount the ProMini directly.
see:
https://forum.arduino.cc/index.php?topic=445951.msg3402425#msg3402425
Normal 0.1" pin headers are OK, trim after soldering with cutters.
Cheap.
I was thinking of incorporating the pro mini into a toy I am going to make 50-100, myself, I would like to keep labor to a minimum. I was hoping I could find male header that was short enough I didn't have to clip it. I specced a custom 12 pin header with .1" posts at samtec but these were $.50 each, I was surprised I didn't find a std header pin for this yet but I'm a novice hardware developer.
If your only making <100, what's the labour in clipping standard headers? Very small. Do the lot in an hour?
If you're talking millions that's a different ballgane.
Allan
perigalacticon:
You can custom order header pins of any shape, form, length, bend, any length plastic carrier. We had to do that for a customer when his headers were discontinued.
Paul
The headers would have been $1 per board, as much as the PCB.
Why do you use cut sockets instead of female headers dave-in-nj?
pert:
much lower profile and cost.
