hello all
I connected ATmega328p right to the USBtinyISP V2.0 as it shown below in attachments.
Then I checked the connection with avrdude through cmd. The connection between PC and the chip was OK.
I opened Arduino with blink LED example and set Programmer to USBtinyISP, Microcontroller to ATmega328p.
When I hit "Burn bootloader" Arduino said "Double check connections".
I tried to check the connection with avrdude through cmd prompt but the chip was dead. What was wrong?
Had I click on upload programmer instead of burn bootloader?
Which bootloader, specifically, did you select?
You have no oscillator on that board. You may need a crystal or ceramic resonator for it to work.
A blank Atmega328 from the factory have the fuses set, so it usesthe internal 8 MHz oscillator. When you burn bootloader, the fuses are set for an external crystal/resonator. If this is not present, the chip is indeed "dead" and you cannot communicate with it. Fit a 16 MHz ceramic oscillator and you will be able to use it again.
// Per.
Thx, I found this tutorial http://arduino.cc/en/Tutorial/ArduinoToBreadboard about oscillator. But what if I'll try "Upload Programmer" button. What is this button for?
GRXG:
If the fuses is set for using an oscillator, and you as missing that, "upload using programmer" won't work.
// Per.
Ok, I think I must to connect the 16MHz oscillator to my board in order to raise it from the dead. And then I will set the fuses for using 8 MHz internal oscillator such as I could remove 16 MHz oscillator, right?
GRXG:
If you want to use the internal oscillator, yes. In that case, set the board for a Lilypad, and "flash bootloader" -then the fuses are set for 8 MHz internal osc.
// Per.
I tried to create a new board "ATmega328 on a breadboard (8 MHz internal clock)".
I copied the file below to "C:\Users\Dereck\Documents\Arduino\hardware\Breadboard\boards.txt"
"C:\Users\Dereck\Documents\Arduino" is a sketchbook folder.
atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
atmega328bb.upload.protocol=USBtinyISP
atmega328bb.upload.maximum_size=30720
atmega328bb.upload.speed=57600
atmega328bb.bootloader.low_fuses=0xE2
atmega328bb.bootloader.high_fuses=0xDA
atmega328bb.bootloader.extended_fuses=0x05
atmega328bb.bootloader.path=arduino:atmega
atmega328bb.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
atmega328bb.bootloader.unlock_bits=0x3F
atmega328bb.bootloader.lock_bits=0x0F
atmega328bb.build.mcu=atmega328p
atmega328bb.build.f_cpu=8000000L
atmega328bb.build.core=arduino:arduino
atmega328bb.build.variant=arduino:standard
Then I restarted my PC.
There are two points:
- Is this line right "atmega328bb.upload.protocol=USBtinyISP" ? (Because I use USBtinyISP V2.0)
- I don't see this custom board in Tools > Board dialog and accordingly I can't use it. What's wrong with it?
Do I need to add the code of new board to the end of this file C:\Program Files (x86)\Arduino\hardware\arduino\avr\boards.txt right?
Thank you all. Everything works perfectly. Problem solved!
I did everything like it said there http://arduino.cc/en/Tutorial/ArduinoToBreadboard
Great
// Per.
