[Solved] Arduino Create Won't load on my pc anymore... :(
I cannot get the arduino web editor to load, it keeps reloading the page and won't let me access it. I get this error code :
"data": null,
"status": -1,
"config": {
"method": "GET",
"transformRequest": [
null
"transformResponse": [
null
"url": "https://auth.arduino.cc/v1/users/byID/me?scopes=core,public,contact,address,private",
"headers": {
"Accept": "application/json, text/plain, /",
"Authorization": "Bearer UVaQSuYQzx-S67zKwsSjq1IUtpfswJYxkuIDlbFbsfk.kPis1sUdwgXhZ5gzMQoGAD-88dyCVsL-k6B9LG5ZR5Q"
"statusText": ""
and i don't know how to decipher it sadly. The page just keeps reloading. I originally started using it on google chrome, but then I began to have this problem, so i downloaded firefox and loaded it up and it worked... for about a week, then it started reloading the create web editor so that I couldn't use it at all. Since it worked and then stopped working, I don't really have a clue what the problem could be.
Also my computer specs are:
Graphics: rx 480 8gb edition
Ram: 16 GB
CPU: AMD 8 core 3.6 gHz
PSU: 1200W
I don't know if this helps so I thought I'd add it if necessary.
Hello, I have the same problem.
me too
Same. I need access to my code :slightly_frowning_face:
I have the same problem and this is not good. I have my project here and I need to progress it.
It looks like the servers are back up if you could clear your caches and try again.
Full access here.
Yes thank you it is working now. cheers/
Yes! Finally!
First: download project (check)
Thanks, Everything is working now :slight_smile:
