I'm using the 6 pin header to connect the arduino mini pro and a USBtinyISP. When I try to upload a sketch to this arduino, I get the avrdude: initialization failed, rc=1 error.
However, when I connect the usbISP to the ICSP of my arduino mega, I can upload a sketch to the mega.
The mini pro receives its voltage, and the power led is on, the other led blinks. (first time I use this arduino board btw).
I'm using the following pinout diagram:
Nothing else is connected to the arduino board yet.
Pictures of the ISP, connector and arduino:
A similar thread
http://forum.arduino.cc/index.php?topic=156431.0
The drivers are installed correctly, my computer(s) detect the USBtinyISP AVR Programmer correctly. However, when I try to upload the sketch using "upload with programmer" it gives me this initialization failed, rc=-1 error, which points to the fact that the connection between usbtinyisp and the arduino mini isn't correct? I've tried several times to start all over again with the wiring and tripple checking my connections to the pin header, but I'm sure that these connections must be correct, using this pinout picture:
I've tried to use an old laptop with windows 7 32bit and my laptop with win 8.1 instead of desktop(win 8 64 bit) so I think I can say that the problem is not situated in the OS that I'm using.
I can't think of any reason it won't work. "-1" is usually a wiring error.
One of the first things you should check is if your "GND" wire coming out of the connector connects back to "GND" on the USBtinyISP (ie. the metal shell of the USB connector). Once that's established, check you have 5V where you expect it.
If not, you got the connector backwards.
After that, try swapping your MISO and MOSI. They're never labelled sensibly.
I'm not sure what the Mega328 pinout diagram has to do with a Pro Mini.
There is no connection between the arduino's GND and the outer shell of the usb connector. however, the internal lines of the usb connector are connected, and my arduino blinks with the default (out of factory) program, and the power-led is on.
Swapping the miso and mosi gave me still the same error.
That pinout was one I found looking for the arduino pro mini?
Another one: http://www.pighixxx.com/pgdev/Temp/ProMini.png
edit* I don't know if its usefull, but here is the output when I try to upload the sketch:
Compiling 'SerialCommunication' for 'Arduino Pro or Pro Mini w/ ATmega328 (5V, 16 MHz)'
Binary sketch size: 5410 bytes (used 18% of a 30720 byte maximum) (0,29 secs)
Minimum Memory Usage: 181 bytes (9% of a 2048 byte maximum)
Uploading to I/O board using 'usbtinyisp'
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
Ward123:
That's not what's in the first post up there ^^
Ward123:
this check.
No, not useful.
If all else fails, suspect the wires/breadboard...
Have you got an oscilloscope? Make sure signals are arriving at the pins on the Pro Mini.
I placed the arduino on a different spot on the breadboard, and used other wires. Using visual studio (and visual micro addin), I succeed uploading a sketch, but the program seems not to be loaded (tried the blinking program, pin status doesn't change, what I checked using my scope.)
Using the Arduino environment (v1.5.4), I get this:
avrdude.exe: error: usbtiny_send: usb_control_msg: sending control message failed, win error: A device attached to the system is not functioning. (expected 128, got -5)avrdude.exe: verification error, first mismatch at byte 0x0008 0x0c != 0x04avrdude.exe: verification error; content mismatch
Could it be that the arduino is broken?
Thinking about a plan B, wouldn't it be easier to use an arduino mega 2560 or arduino nano to act as an ISP, and upload my sketches using a second arduino? ![]()
Ward123:
It could be that the ISP isn't configured correctly and is sending data too fast. I'm not sure how to change that.
Try selecting "8MHz" in the list of boards.
Ward123:
Easiest way would be to get an FTDI adaptor and use the six pin connector you soldered on the end of the Pro Mini.
(Although you might have killed the bootloader by now)
Unfortunately again the same error it gave me last time.
But the comminucation led starts flickering when the uploading process starts.
Some info from my oscilloscope: the signals on MOSI/MISO are lasting for approximately 2 seconds. But I don't really know what to look for in these signals...
Make sure RESET goes fully low during communication.
I tied down the reset pin using a wire, no change however ![]()
Can you turn on verbose info and see what the fuse bits are? Maybe they turned off SPI programming (unlikely but we have to eliminate it)
Seems like 'the problem solved itself' put my arduino on the side for a while and today was miraculously enough able to upload the sketch. The avrdude.exe: error: usbtiny_send: usb_control_msg: sending control message failed, win error: A device attached to the system is not functioning. (expected 128, got -5) error was still there, but the program is running fine.
