New to arduino for class project
Any help on how to connect sparkfun adxl335 accelerometer to lilypad arduino
trying to use accellerometer to light up LEDs like a speedometer
any help greatly appreciated!
Thanks
Thanks
Did you try the link called "wiring example"?
Which "lilypad arduino"?
https://www.sparkfun.com/search/results?term=lilypad+arduino
Guess it doesn't matter, looks like all have 3 analog ports available.
You may have to find a 3.3V voltage supply source for the accelerometer if the Lilypad is powered at 5V.
I was thinking of running the lilypad board:
to a lilypad twinkle
and then have the accelerometer control the LEDs off of the twinkle (ie 1 light 10mph, 2-20mph... up to 5 LEDs)
having a little bit of a struggle because the board has +, -, analog 2-5, digital 5-11
Connect Accel. to the first board per the Wiring example on the Accel page.
3 analog outputs to 3 analog inputs, Gnd to Gnd, and Power from a 3.3V source. It looks like the board is running at 8 MHz, so you can probably power the accel from the Arduino power.
Use one of the VCC pins - check it with a meter first to make sure.
