I am using the sample code from the Elegoo Uno R3 board starter kit along with the kit's stepper motor. The idea is to have a remote control trigger the motor to move one direction or the other for a complete rotation. This much works well when the motor speed is set to the default value(500). But I would like the rotation to go more slowly. When I change the default speed to less than 500 (I have tried 200, 300, 400), it rotates once fully as it should on the first round. But when I click the remote again, the next move is never a full rotation. It seems as if something is interrupting and stopping the motor. Further clicks of the remote provide further inconsistent turns...I can't seem to find any pattern in how far it turns with successive clicks, but always less than a full rotation and rarely more than half a rotation. I checked the motor temperature, it's not even warm. Here is the wiring diagram and code:
//www.elegoo.com
//2016.12.12
#include "Stepper.h"
#include "IRremote.h"
/*----- Variables, Pins -----*/
#define STEPS 32 // Number of steps per revolution of Internal shaft
int Steps2Take; // 2048 = 1 Revolution
int receiver = 12; // Signal Pin of IR receiver to Arduino Digital Pin 6
/*-----( Declare objects )-----*/
// Setup of proper sequencing for Motor Driver Pins
// In1, In2, In3, In4 in the sequence 1-3-2-4
Stepper small_stepper(STEPS, 8, 10, 9, 11);
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) // have we received an IR signal?
switch(results.value)
case 0xFFA857: // VOL+ button pressed
small_stepper.setSpeed(200); //Max seems to be 500--THIS IS THE VALUE THAT I CHANGE!
Steps2Take = 2048; // Rotate CW
small_stepper.step(Steps2Take);
delay(2000);
case 0xFF629D: // VOL- button pressed
Steps2Take = -2048; // Rotate CCW
delay(2000);
irrecv.resume(); // receive the next value
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
}/* --end main loop -- */
The motor is a 28BYJ-48 4-Phase Stepper Motor with the ULN2003 5V Drive Board for Arduino.
Thanks for any help you can provide!
