I am new on this forum, but I have been reading you guys post for the last 2 weeks trying to find a solution to my problem.
I really found nothing, so I'm asking for help here.
I have a motor, arduino uno, DRV8825, 12VDC powersupply and USB/12VDC Arduino powersupply.
I' ve put DRV8825 (0.1Ohm) Vref to 0.70V, the motor spec being 1.5A.
However, as soon as I plug the motor and power the arduino and it, all it does is vibrate.
There is no program in the arduino so I don' t get it.
I also checked the coils and they are correct, Green and Black make the motor harder to rotate, same goes for white and blue.
Breadboards are for low power logic circuits and can't handle the current required for motors (the tracks burn). You will need to solder motor power and motor wires to the DRV8825 driver.
Finally, make sure you have set the current limit correctly on the DRV8825.
The driver being powered by arduino, and connected to the 12V for the motor, the motor should hold still. Not be free.
That's what a driver do!
Sending a signal via arduino would make it rotate.
Can you please post a circuit diagram of your project please?
The Fritzy has no resolution to read pins names.
In fact Fritzy are pretty hopeless when it come to troubleshooting.
It would be better if you use pen(cil) and paper and draw your circuit from your project.
Please label components and pins/connections.
Have you tried to load some code to control your stepper?
You don't know what code is currently on your UNO?
So anything can be causing the vibrations.
