TFT_eSPI - new example for animated dials
The TFT_eSPI library has been updated with a new example that shows how animated dials can be created with indicator needles that can sweep over graphics. To run the example the TFT setup must permit the TFT RAM to be read.
The new "Animated_dial" example uses a JPEG image of a dial so this permits more sophisticated looking dials and gauges to be created:
Hi Bodmer I'm sorry to bother your library and the best in everything I'm using with esp32 and it's amazing about the example TFT_ring_meter how I manage to make the bar just horizontal without being arched as in the video and photo below, I know you it must be very busy but i would be very grateful for the help i'm desperate i need for a college job and i'm still walking in programming i'm from brazil so i'm sorry for the bad english ok
@Alexandrelv
The bar is just a series of filled rectangles. The only tricky bit is the colour change. Try this:
 An example showing linear analogue meter
// Meter colour schemes
#define RED2RED     0
#define GREEN2GREEN 1
#define BLUE2BLUE   2
#define BLUE2RED    3
#define GREEN2RED   4
#define RED2GREEN   5
#define RAINBOW     6
#include <TFT_eSPI.h>
#include <SPI.h>
TFT_eSPI tft = TFT_eSPI();
int reading = 0;
void setup(void) {
  tft.begin();
  tft.setRotation(0);
  tft.fillScreen(TFT_BLACK);
  linearMeter(reading, 10,  10, 5, 25, 3, 20, RED2RED);
  linearMeter(reading, 10,  40, 5, 25, 3, 20, GREEN2GREEN);
  linearMeter(reading, 10,  70, 5, 25, 3, 20, BLUE2BLUE);
  linearMeter(reading, 10, 100, 5, 25, 3, 20, BLUE2RED);
  linearMeter(reading, 10, 130, 5, 25, 3, 20, GREEN2RED);
  linearMeter(reading, 10, 160, 5, 25, 3, 20, RED2GREEN);
  linearMeter(reading, 10, 190, 5, 25, 3, 20, RAINBOW);
  reading++;
  if (reading > 20) { reading = 0; delay(1000); }
  delay (50);
//  Draw the linear meter
// val =  reading to show (range is 0 to n)
// x, y = position of top left corner
// w, h = width and height of a single bar
// g    = pixel gap to next bar (can be 0)
// n    = number of segments
// s    = colour scheme
void linearMeter(int val, int x, int y, int w, int h, int g, int n, byte s)
  // Variable to save "value" text colour from scheme and set default
  int colour = TFT_BLUE;
  // Draw n colour blocks
  for (int b = 1; b <= n; b++) {
    if (val > 0 && b <= val) { // Fill in coloured blocks
      switch (s) {
        case 0: colour = TFT_RED; break; // Fixed colour
        case 1: colour = TFT_GREEN; break; // Fixed colour
        case 2: colour = TFT_BLUE; break; // Fixed colour
        case 3: colour = rainbowColor(map(b, 0, n, 127,   0)); break; // Blue to red
        case 4: colour = rainbowColor(map(b, 0, n,  63,   0)); break; // Green to red
        case 5: colour = rainbowColor(map(b, 0, n,   0,  63)); break; // Red to green
        case 6: colour = rainbowColor(map(b, 0, n,   0, 159)); break; // Rainbow (red to violet)
      tft.fillRect(x + b*(w+g), y, w, h, colour);
    else // Fill in blank segments
      tft.fillRect(x + b*(w+g), y, w, h, TFT_DARKGREY);
** Function name:           rainbowColor
** Description:             Return a 16 bit rainbow colour
  // If 'spectrum' is in the range 0-159 it is converted to a spectrum colour
  // from 0 = red through to 127 = blue to 159 = violet
  // Extending the range to 0-191 adds a further violet to red band
uint16_t rainbowColor(uint8_t spectrum)
  spectrum = spectrum%192;
  uint8_t red   = 0; // Red is the top 5 bits of a 16 bit colour spectrum
  uint8_t green = 0; // Green is the middle 6 bits, but only top 5 bits used here
  uint8_t blue  = 0; // Blue is the bottom 5 bits
  uint8_t sector = spectrum >> 5;
  uint8_t amplit = spectrum & 0x1F;
  switch (sector)
    case 0:
      red   = 0x1F;
      green = amplit; // Green ramps up
      blue  = 0;
    case 1:
      red   = 0x1F - amplit; // Red ramps down
      green = 0x1F;
      blue  = 0;
    case 2:
      red   = 0;
      green = 0x1F;
      blue  = amplit; // Blue ramps up
    case 3:
      red   = 0;
      green = 0x1F - amplit; // Green ramps down
      blue  = 0x1F;
    case 4:
      red   = amplit; // Red ramps up
      green = 0;
      blue  = 0x1F;
    case 5:
      red   = 0x1F;
      green = 0;
      blue  = 0x1F - amplit; // Blue ramps down
  return red << 11 | green << 6 | blue;
Since this just uses the fill Rectangle function it should be easily adaptable to other graphics libraries.
Bodner friend thank you very much it was perfect it helped me a lot you are amazing saved me, thank you
anmiated = animated ?
Sorry, I do not speak english and google translate do not understand.
@bodmer : in what way can this coloursceme be adjusted? I mean, I am using a single bar with RED2GREEN. However, using the scale that I do, the red rectangles stop at 50% of the scale, where I want the red to stop at about 15% of the scale, then turn into yellow up to about 25% and turn into green for the rest of the scale.
My scale is filled with 30 rectangles.
Hope to hear from you.
Arno
