I have a problem with the RFID RC-522 reader in a device I created. I am using an ESP32 connected to pins SDA=16 and RST=22. At one point, while the system was working, the RST pin stopped working. I then changed it to pin 21, and it worked for a while, but the problem recurred, and the RFID stopped working again. Has anyone found a solution to this issue? I have already tried it with an Arduino Uno, and it successfully read the RFID, so I assume the RC-522 RFID module is functioning correctly.
my program:
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#include <MFRC522.h>
#include <HTTPClient.h>
#include <DHT.h>
#include <RBDdimmer.h>
#define SDA_PIN 16
#define RST_PIN 22
#define LAMP_INDICATOR 13
#define SOLENOID 12
#define outputPin 27
#define zerocross 26
#define DHTPIN 17
#define DHTTYPE DHT22
MFRC522 mfrc522(SDA_PIN, RST_PIN);
DHT dht(DHTPIN, DHTTYPE);
dimmerLamp dimmer(outputPin, zerocross);
const int batas_maks_sudut_picu = 120;
const int batas_min_sudut_picu = 80;
String IDTAG = "";
String statusMessage = "";
unsigned long previousRFIDTime = 0;
unsigned long previousTempHumTime = 0;
unsigned long previousSpeedChangeTime = 0;
unsigned long previousIFTTTTime = 0;
const unsigned long rfidInterval = 500;
const unsigned long tempHumInterval = 1000;
const unsigned long speedChangeInterval = 500;
const unsigned long accessDeniedDuration = 5000; // 5 seconds
const unsigned long IFTTTInterval = 1000; // 1 second
bool accessDenied = false;
unsigned long accessDeniedStartTime = 0;
String value1ToSend = "";
String value2ToSend = "";
String value3ToSend = "";
mfrc522.PCD_Init();
pinMode(LAMP_INDICATOR, OUTPUT);
pinMode(SOLENOID, OUTPUT);
dht.begin();
dimmer.begin(NORMAL_MODE, ON);
Blynk.begin(auth, ssid, pass);
Blynk.run();
if (accessDenied && (currentMillis - accessDeniedStartTime >= accessDeniedDuration)) {
if (!accessDenied && currentMillis - previousRFIDTime >= rfidInterval) {
readRFID();
previousRFIDTime = currentMillis;
if (!accessDenied && !mfrc522.PICC_IsNewCardPresent()) {
if (currentMillis - previousTempHumTime >= tempHumInterval) {
readTemperatureHumidity();
updateDimmerAngle(currentMillis);
previousTempHumTime = currentMillis;
if (currentMillis - previousIFTTTTime >= IFTTTInterval) {
sendIFTTTData();
previousIFTTTTime = currentMillis;
void readRFID() {
if (mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial()) {
IDTAG = "";
for (byte i = 0; i < mfrc522.uid.size; i++) {
IDTAG += mfrc522.uid.uidByte[i];
if (IDTAG == "1631169166") controlLEDs("GROUP1");
else if (IDTAG == "22787245166") controlLEDs("GROUP2");
else if (IDTAG == "2225594175") controlLEDs("GROUP3");
else {
value1ToSend = "AKSES DITOLAK " + IDTAG;
sendIFTTTData();
Blynk.virtualWrite(V2, "Akses ditolak");
accessDenied = true;
accessDeniedStartTime = millis();
void controlLEDs(String group) {
static bool areLEDsOn = false;
if (areLEDsOn) {
digitalWrite(LAMP_INDICATOR, LOW);
digitalWrite(SOLENOID, LOW);
statusMessage = group + " CLOSE";
digitalWrite(LAMP_INDICATOR, HIGH);
digitalWrite(SOLENOID, HIGH);
statusMessage = group + " OPEN";
areLEDsOn = !areLEDsOn;
Blynk.virtualWrite(V2, statusMessage);
void readTemperatureHumidity() {
float temperature = dht.readTemperature();
float humidity = dht.readHumidity();
Blynk.virtualWrite(V0, temperature);
Blynk.virtualWrite(V1, humidity);
String value3 = getBlowerSpeedString(temperature);
value1ToSend = statusMessage;
value2ToSend = "Temperature: " + String(temperature) + "°C, Humidity: " + String(humidity) + "%";
value3ToSend = value3;
String getBlowerSpeedString(float temperature) {
if (temperature >= 34 && temperature <= 36) {
return "Kecepatan Blower: 1";
} else if (temperature >= 36 && temperature <= 38) {
return "Kecepatan Blower: 2";
} else if (temperature >= 38 && temperature <= 40) {
return "Kecepatan Blower: 3";
return "";
void updateDimmerAngle(unsigned long currentMillis) {
int angle = 0;
angle = 80;
angle = 100;
angle = 120;
if (angle != 0 && currentMillis - previousSpeedChangeTime >= speedChangeInterval) {
setDimmerAngle(angle);
previousSpeedChangeTime = currentMillis;
void setDimmerAngle(int angle) {
int persen_pemotongan_tegangan = map(angle, 0, 180, 0, 100);
dimmer.setPower(persen_pemotongan_tegangan);
String speed = getBlowerSpeedString(dht.readTemperature());
Blynk.virtualWrite(V3, speed);
void sendIFTTTData() {
HTTPClient http;
String payload = String("{ \"value1\": \"") + value1ToSend + "\", \"value2\": \"" + value2ToSend + "\", \"value3\": \"" + value3ToSend + "\" }";
http.begin(IFTTTUrl);
http.addHeader("Content-Type", "application/json");
int httpResponseCode = http.POST(payload);
http.end();
