Hello everyone,
I was following this tutorial, trying to make a trip computer for my car. I am using an arduino Uno, and, I am in a very beginner level.
Generally, I understand what the code does, but, the output I get does not make sense to me.
Let me explain. The working principal of the whole project, is to count the pulses you get form the injector harness and the VSS sensor. Those 2, will give you speed and fuel flow rate values. Combining them, you can get instant, average consumption, speed, average speed etc.
Trying it, the result was not what I expected. I want you guys, to take a look at the code, and, if possible, tell me if there is anything wrong with it.
Here is the code I have.
#include <DS1307RTC.h>
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <Wire.h> // IIC LIBRARY
#include <LiquidCrystal.h>
#include <EEPROMex.h>
#include <EEPROMVar.h>
//I2C network adresses for RTC and LCD
#define I2C_ADDR 0x3F;//I2C Adress
#define I2C_ADDR 0x50;//I2C Adress
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
//variables declaration
//injector flow l/sec
volatile static long double injector_value = 0.002875166;
//pulses per km
volatile static double pulse_distance = 0.000397545;
volatile unsigned long counter, avg_speed_divider, distance_pulse_count, all_speed_values, all_fuel_consumption_values, temp_distance_pulse_count, injector_pulse_time, temp_injector_pulse_time, injTime1, injTime2, save_number;
volatile unsigned int speed, avg_speed, max_speed=0, fccounter, save_counter, i;
volatile double traveled_distance, display_speed, display_instant_fuel_consumption, display_traveled_distance, injector_open_time, used_fuel, tank_capacity = 40, average_fuel_consumption, instant_fuel_consumption;
volatile boolean to_be_saved;
lcd.begin(20,4);
lcd.clear();
noInterrupts();
TCCR1A = 0;
TCCR1B |= ((1 << CS10) | (1 << CS11));
TIMSK1 |= (1 << TOIE1);
TCNT1 = 3036;
pinMode(1, INPUT); //Injector
pinMode(2, INPUT);//VSS
pinMode(3, INPUT); //Reset
digitalWrite(1, HIGH);
digitalWrite(2, HIGH);
digitalWrite(3, HIGH);
attachInterrupt(digitalPinToInterrupt(1), injector_count, CHANGE);
attachInterrupt(digitalPinToInterrupt(2), distance_count, FALLING);
//EEPROM.setMemPool(0, 1024);
//loadData();
interrupts();
//reset data
if (digitalRead(3) == LOW) {
traveled_distance = 0;
used_fuel=0;
all_fuel_consumption_values = 0;
avg_speed_divider=0;
if(millis()%1000 == 0){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("V");
lcd.setCursor(2,0);
lcd.print(display_speed);
lcd.setCursor(6,0);
lcd.print("km/h");
lcd.setCursor(0,1);
lcd.print("DST");
lcd.setCursor(4,1);
lcd.print(display_traveled_distance, 1);
lcd.setCursor(9,1);
lcd.print("km");
lcd.setCursor(0,2);
lcd.print("AFC");
lcd.setCursor(4,2);
lcd.print(average_fuel_consumption, 1);
lcd.setCursor(9,2);
lcd.print("l/100");
lcd.setCursor(14,1);
lcd.print("SVN");
lcd.setCursor(18,1);
lcd.print(save_number);
lcd.setCursor(11,0);
lcd.print("UF");
lcd.setCursor(14,0);
lcd.print(used_fuel, 2);
lcd.setCursor(19,0);
lcd.print("L");
lcd.setCursor(0,3);
lcd.print("IFC");
lcd.setCursor(4,3);
lcd.print(display_instant_fuel_consumption, 1);
lcd.setCursor(8,3);
if (speed > 3) lcd.print("lt/100");
else lcd.print("L/h");
lcd.setCursor(12,3);
lcd.print(tank_capacity);
lcd.setCursor(18,3);
lcd.print("lt");
// void saveData(){
// EEPROM.writeInt(0, max_speed);
//void loadData(){
// EEPROM.readInt(0);
// max_speed= EEPROM.readInt(0);
// if (isnan (EEPROM.readInt(0))) max_speed=0;
void maxSpeed(){
if (speed > max_speed) max_speed = speed;
void avgSpeed(){
all_speed_values += speed;
avg_speed = all_speed_values / avg_speed_divider;
void distance_count(){
distance_pulse_count++;
traveled_distance += pulse_distance;
temp_distance_pulse_count++;
void injector_count(){
if (digitalRead(1) == LOW) {
injTime1 = micros();
else {
injTime2=micros();
injector_pulse_time= injector_pulse_time + (injTime2 - injTime1);
temp_injector_pulse_time = temp_injector_pulse_time + (injTime2 - injTime1);
void currentSpeed(){
if(speed ==0 && distance_pulse_count >20){
traveled_distance -= pulse_distance * distance_pulse_count;
speed = pulse_distance* distance_pulse_count *3600;
void fuel_consumption(){
injector_open_time = ((double)injector_pulse_time / 1000000);
if (speed>3){
instant_fuel_consumption = (100 * (((injector_open_time * injector_value)*3600)*4)) / speed;
all_fuel_consumption_values += instant_fuel_consumption;
average_fuel_consumption = all_fuel_consumption_values / avg_speed_divider;
else instant_fuel_consumption = ((injector_open_time * injector_value)*3600) * 4;
if(speed ==0 && instant_fuel_consumption >5 || instant_fuel_consumption > 80){
instant_fuel_consumption = 0;
injector_open_time = 0;
used_fuel += ((injector_open_time * injector_value)*4);
if (tank_capacity > 0) tank_capacity = 45 - used_fuel;
ISR(TIMER1_OVF_vect) {
counter++;
if (temp_injector_pulse_time <800 && temp_distance_pulse_count ==0 && to_be_saved ==1) saveData();
if (save_counter > 45 && speed ==0 && to_be_saved ==1 ) saveData();
temp_injector_pulse_time=0;
temp_distance_pulse_count =0;
if(counter>3){
currentSpeed();
fuel_consumption();
if (instant_fuel_consumption >0.3) to_be_saved=1;
if (speed >3) {
avg_speed_divider++;
avgSpeed();
maxSpeed();
save_counter++;
distance_pulse_count = 0;
counter = 0;
display_instant_fuel_consumption = instant_fuel_consumption;
display_traveled_distance = traveled_distance;
display_speed = speed;
TCNT1 = 3036;
Best regards,
Kostas
