Vehicle Speed Sensor *Input*
Howdy folks, it's been a long, long time since I played with Arduinos/hardware solutions to software problems, so first and foremost, please be patient with me and consider me a rookie. I'm not new to programming, but it's been a long time since I did hardware interaction.
I'm aware of a myriad (1) of related prior posts (I could easily link more...), and at this point, my head is spinning.
Root of the project/problem:
I have a vehicle speed sensor ("VSS", pretty sure it's a hall effect sensor) that outputs a TON of square waves (min just over 0V, max something like 2.7v).
Like thousands of them a second (eg measure the wave frequency in microseconds). When it's linked directly to the speedometer, the speedo reads wrong. And not just a couple MPH off. We're talking orders of magnitude wrong.
I'm aware of Tim Toolman's similar project; in fact, I hope to leverage his code to output the (more) correct MPH.
What I have no damn idea what I'm doing for: VSS input. Specifically, I need a way to read in the VSS signal, and then once I am successfully doing so, do whatever sort of maths I need to, in order to re-translate it into a more accurate reading.
Seeing a LOT of conflicting information on that which makes my head hurt (again, been out of the game a long time). Some people use the TimerOne library (as Tim above does); but doesn't that interfere with above output, and it's doing "too much work" for one board (I've heard this a few times)? Some people do it all with interrupts (ughhhh, but if I have to), and if that's the case, how does THAT play with output...
I feel very lost and confused as to where to even start with this input problem.
Any and all advice (and sample code) would be greatly appreciated.
Please post a link to the data sheet of the hall sensor.
Please tell which Arduino You are using.
Please post the code, autoformatted in the IDE and use code tags, the </> symbol, when pasting.
I don't have a data sheet of the sensor. Just some scope readings.
I bigger picture want to be able to figure out how to read in that stuff myself and do something useful. I just want somewhere to start.
I'm using an Arduino Uno from like...at least 7 years ago, and I have a handful of Nanos I eventually will switch to that are about the same age.
There's all the code I have to-date that definitely works.
Does the sensor have a brand name and part number? Can you post a picture? Hall sensors are switched by magnets passing near them, how many magnets are on the wheel you are trying to read?
But what is it connected to that is moving so fast and how is it connected to that thing.
A Honda Civic.
Reply
cgordini
34m
Paul_KD7HB:
A Honda Civic.
`l like your spirit. The Hall effect sensor, when energized, provides a reference. Useful data occurs then a magnet passes nearby and disturbs the reference signal. Those disturbances are what you want to count. Some magnets maybe mounted on a wheel (eg bicycle) or a driveshaft, (some cars). Nice graphics at What is Hall Effect and How Hall Effect Sensors Work - YouTube
Show the sensor specs.
Values for digital out doesn't seem correct.
You might be trying to apply the wrong type of hall sensor.
