Hello everyone! I may be a Newbie on the Forum but I have over 1.5 years of experience in Arduino...The Touch Sensor is a sensor which sends a HIGH signal to your Arduino when you touch it or if you have not touched it sends a LOW signal to your digital pin.
I am posting this cause not all people know there is a touch sensor. A touch sensor acts similar to a button...Actually it is basically a button but just that you don't need to press anything just touch the middle of the small sensor.
Check out my new Arduino Tutorial on YouTube :-
So the touch sensor has 3 pins - VCC, GND, SIG.
VCC - 5V, 3.3V
GND - Ground Pin
SIG - Any Digital Pin ( using pin 9 in this case )
I feel that this sensor is way easy to connect and work with than a button...
Here, I'm going to turn on an LED when the touch Sensor you know, is touched. The code is same as a button's code :-
int touchPin = 9; // Touch Sensor's Pin
int touchState; // The state of the Sensor
int ledPin = 13; // The LED Pin
pinMode ( ledPin, OUTPUT );
pinMode ( touchPin, INPUT );
touchState = digitalRead ( touchPin );
if ( touchState == HIGH )
digitalWrite ( ledPin, HIGH );
digitalWrite ( ledPin, LOW );
