I still think SPI will mess me up quite a bit, considering all the issues to consider (from my limited reading about it).
You see, my problem is that I want to keep my wires to 8, so I can use a Cat5 cable to connect the Arduino to a second button/LED box in a different room. In order to use a newer input shift register, SN74HC165N, I need Vcc, ground, clock, clock enable, serial in, and latch (sorry about the terminology mixup here), which leaves me with 2 for the output shift register, TPIC6B595. I can share the Vcc and ground, and so I am only 1 short. If I can also share the latch then I am set, but I suspect I cannot, unless I use SPI. Is that correct?
If that is correct, then the older input register, CD4021BE, would be better, because it only uses clock, serial in, and latch. Again, is this correct? If so, then I could use the Cat5 cable.
The code I am planning on using for the former case is the following. Can the latch be shared somehow easily in it?
* SN74HC165N_shift_reg
* Program to shift in the bit values from a SN74HC165N 8-bit
* parallel-in/serial-out shift register.
* This sketch demonstrates reading in 16 digital states from a
* pair of daisy-chained SN74HC165N shift registers while using
* only 4 digital pins on the Arduino.
* You can daisy-chain these chips by connecting the serial-out
* (Q7 pin) on one shift register to the serial-in (Ds pin) of
* the other.
* Of course you can daisy chain as many as you like while still
* using only 4 Arduino pins (though you would have to process
* them 4 at a time into separate unsigned long variables).
/* How many shift register chips are daisy-chained.
#define NUMBER_OF_SHIFT_CHIPS 2
/* Width of data (how many ext lines).
#define DATA_WIDTH NUMBER_OF_SHIFT_CHIPS * 8
/* Width of pulse to trigger the shift register to read and latch.
#define PULSE_WIDTH_USEC 5
/* Optional delay between shift register reads.
#define POLL_DELAY_MSEC 1
/* You will need to change the "int" to "long" If the
* NUMBER_OF_SHIFT_CHIPS is higher than 2.
#define BYTES_VAL_T unsigned int
int ploadPin = 8; // Connects to Parallel load pin the 165
int clockEnablePin = 9; // Connects to Clock Enable pin the 165
int dataPin = 11; // Connects to the Q7 pin the 165
int clockPin = 12; // Connects to the Clock pin the 165
BYTES_VAL_T pinValues;
BYTES_VAL_T oldPinValues;
/* This function is essentially a "shift-in" routine reading the
* serial Data from the shift register chips and representing
* the state of those pins in an unsigned integer (or long).
BYTES_VAL_T read_shift_regs()
long bitVal;
BYTES_VAL_T bytesVal = 0;
/* Trigger a parallel Load to latch the state of the data lines,
digitalWrite(clockEnablePin, HIGH);
digitalWrite(ploadPin, LOW);
delayMicroseconds(PULSE_WIDTH_USEC);
digitalWrite(ploadPin, HIGH);
digitalWrite(clockEnablePin, LOW);
/* Loop to read each bit value from the serial out line
* of the SN74HC165N.
for(int i = 0; i < DATA_WIDTH; i++)
bitVal = digitalRead(dataPin);
/* Set the corresponding bit in bytesVal.
bytesVal |= (bitVal << ((DATA_WIDTH-1) - i));
/* Pulse the Clock (rising edge shifts the next bit).
digitalWrite(clockPin, HIGH);
digitalWrite(clockPin, LOW);
return(bytesVal);
/* Dump the list of zones along with their current status.
void display_pin_values()
Serial.print("Pin States:\r\n");
Serial.print(" Pin-");
Serial.print(i);
Serial.print(": ");
if((pinValues >> i) & 1)
Serial.print("HIGH");
Serial.print("LOW");
Serial.print("\r\n");
/* Initialize our digital pins...
pinMode(ploadPin, OUTPUT);
pinMode(clockEnablePin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, INPUT);
/* Read in and display the pin states at startup.
pinValues = read_shift_regs();
display_pin_values();
oldPinValues = pinValues;
/* Read the state of all zones.
/* If there was a chage in state, display which ones changed.
if(pinValues != oldPinValues)
Serial.print("*Pin value change detected*\r\n");
delay(POLL_DELAY_MSEC);
