UNO r4 wifi IOT cloud not working
almost nothing is working:
  1. i am creating a remote control project with my arduino uno r4 wifi, so i create a new thing, then add one boolean cloud variable, and make the serial print it every time it changes. the serial show it connected to wifi but then did not connect to the cloud server. i do not remember exactly but somthing like: 1885 , error -2.
  2. to fix this, i tryed creating a new thing and leaving it blank exept for the wifi connection and once again a test bool variable. same issue.
  3. i see that board software it not at the lattest version, so, after manny tryes, i sucessfully update it. then try again STILL NOT WORKING
  4. i delet device and try reconecting it. the cloud agent not installed screen shows up for less than a secont then disapers, and soon after my board if found. then i name it UNO_R4. then it gets stuck on the #3 and after a long time shows this:
    We were not able to configure your device
Something went wrong!
Please try to:
  • Restart the Create Agent on the computer.
  • Detach the device from any shield/carrier or external circuitry
  • Reconnect the device to the computer and make sure the power LED lights up.
  • Make sure the desktop IDE is closed.
  • Reset your device
5: retry a few times, tehn it works, but back in the thing, with the device associated, it is never found (always disconnected so i can not upload the sketch) and device allways shows the offline status.
6: i tried disconnecting and reconnecting manny times, and nothing works. their seems to be problems that somtimes happen at every step of the way, but never being able to upload a sketch
IT Works now! i waited a few hours, then, i tryed it on another device(it worked) before going back to thhe original one(they both Work)
