Is there a way I can run the Uno from a 4.3v supply? I know the AVR can be run from 5v or 3.3v, at 16 or 8 mHz, but I haven't ever heard about a voltage between.
Looks like you can run the 328 / 328p at anywhere from 1.8 to 5.5v. Not sure about the speeds you can run at various voltages, but if I had to guess I'd say you'd be safe using the internal oscillator. (Edit: looks like someone answered this question: http://arduino.cc/forum/index.php/topic,101084.0/topicseen.html )
Also, I believe the analog reference voltage can't exceed Vcc.
The Uno itself has a voltage regulator that needs 6-12v in order to output 5v.
I have a speed/voltage table here:
At 4.32V you could run at 19 MHz.
At 4.14V you could run at 18 MHz.
For 16 MHz (which a Uno uses) you only need 3.78V.
You would bypass the voltage regulator (assuming you don't exceed 5V) and just plug into the +5V pin.
Thank you both very much!
BTW, how come the regulator doesn't mind if you put 5v on it's output, when not powering the input?
I can't see it documented for this particular one but apparently there exists a "Reverse Current Protection Circuit" which "stops the reverse current if the Reverse Detector detects that the VOUT pin voltage has become higher than the VDD pin voltage.".
mattallen37:
Because the schematic asked nicely.
You can actually go somewhat lower yet (around 3.2v, maybe a bit lower) at 16Mhz but it is out of spec so not recommended.
Thank you all! I only need to go down to around 4.3v (Lego NXT sensor supply), but the extra info is good to know!
