Upload fails: 'did not find any USB device "usb"'
My case may be interesting in that the error output is somewhat different.
I use an official AtMEGA 2560 board with IDE 1.8.9. Everything worked fine until yesterday ( meaning successful uploads for several days)
Of course I still use the good port : COM6 for me (the only one that appears when I connect the board !)
Now I get that same message with windows 10, Linux Debian, two different machines and two different cables :
C:\Users\JP\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\JP\AppData\Local
\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega2560 -cstk500v2 -Pusb -Uflash:w:C:\Users\JP\AppData
\Local\Temp\arduino_build_978917/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\JP\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-
arduino17/etc/avrdude.conf"
         Using Port     : usb
An error occurred while uploading the sketch
         Using Programmer              : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
avrdude done.  Thank you.
I am trying with the blink sketch here. I must add that since yesterday I succeeded uploading twice but failed innunmerable times. May it have some connection with recent avrdude updates ?
Too bad that the only suggested solution is to select the right port. Obviously my problem is very different with my config :
Maybe a faulty board ? Strange, since I get the informations from the board through the USB connection.
jptrol:
Your problem is caused by holding the Shift key while you click the Upload button. That causes the Arduino IDE to do an "Upload Using Programmer" instead of a standard Upload. Since you don't have an ISP programmer connected, that won't work, thus the error.
pert:
Thank you for your help Pert. Though I can't remember hitting the shift key or clicking the programmer option , the fact is that when I carefully select upload or CTRL U I now succeed every time I try. May it go on !
Thank you again.
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
